Results 1 to 4 of 4
  1. #1
    Default 1992 40hp blown 20amp fuse & fried red rectifier wire
    Any ideas as to what might cause these two issue - blown fuse and fried red wire to rectifier (at least I think it is the rectifier in pic)..do I just have a bad rectifier or would the burned up red wire to rectifier and blown fuse be an indication of another problem? Motor was in shop at beginning of season and the primer pump was replaced and I also noticed they put in new fuse & fuse holder. Not sure if there could be any relation to the work and current issue? Any help / insight appreciated! ThxClick image for larger version.
ID:	16516Click image for larger version.
ID:	16517Click image for larger version.
  2. #2
    Default Re: 1992 40hp blown 20amp fuse & fried red rectifier wire
    I found info on another site and some old threads that suggests issue could be bad battery connection (I was using wing nuts) or perhaps battery leads may have been attached incorrectly even for a moment (don't think so), battery could have a bad cell, or a short somewhere. Also suggested stator could also be fried, not just rectifier. Ordered a new rectifier - maybe it will rectify my problem��. Any comments welcome.
  3. #3
    Join Date
    Apr 2010
    Posts
    4,043
    I've seen that happen when the battery leads were reversed.
  4. #4
    Join Date
    Apr 2010
    Posts
    4,043
    What did you find ????
Similar Threads
  1. Fried Rectifier
    By Alski in forum Johnson Evinrude Outboard Forum
    Last Post: 11-08-2016, 08:43 AM
  2. 2002 mariner f75 blowing 20amp fuse
    By rodey in forum Mercury Mariner Outboard Forum
    Last Post: 08-12-2015, 04:32 PM
  3. 1992 40HP Force Kill Wire Question
    By ko4nrbs in forum Chrysler Force Outboard Forum
    Last Post: 07-22-2014, 10:41 PM
  4. Blown OMC Rectifier/Regulator 1992 115 hp V4 X-flow
    By chriscrafter in forum Johnson Evinrude Outboard Forum
    Last Post: 04-01-2010, 03:18 AM
  5. Trim unit blowing 20amp fuse
    By donziak in forum Mercruiser Sterndrive Archive
    Last Post: 06-26-2008, 11:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
