Results 1 to 8 of 8
  1. #1
    Default MerCruiser alpha one v8 can some help me identify where this noise is coming from
    can some one plz help me out every time I start the engine there is a knocking noise coming behind the engine https://www.youtube.com/watch?v=tpDZdHSt4To plz help
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,891
    Default Re: MerCruiser alpha one v8 can some help me identify where this noise is coming from
    guessing the gimbal bearing, remove the drive and retest
  3. #3
    Quote Originally Posted by landy View Post
    If is the gimbal bearing do i have to change it right away ??
  4. #4
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,891
    gimbal bearings die form water intrusion and the same water gets into the U joints too. A exploding U joint at 4400 rpm is like a small grenade . The whipping action of the center section can destroy the transom housing or create a bigger leak than your bilge pump can handle.
    A $6.00 gasket is a whole lot cheaper
  5. #5
    I will change it right away thank u some much
  6. #6
    Now is. Making this knocking noise https://youtu.be/45IHajJS-ZI
  7. #7
    Join Date
    Nov 2005
    Location
    Mt. Zion, Illinois,
    Posts
    543
    That sounds like lifter noise.
    KJ
  8. #8
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,891
    I think the growling gimbal bearing was masking the lifter tick. Only now with the drive removed can you hear the lifter. As light as it is I would not worry unless it gets a lot louder
Similar Threads
  1. Help to identify 5.7 noise
    By Simonas in forum Mercruiser Sterndrive Forum
    Last Post: 11-04-2017, 09:00 AM
  2. Replies: 39
    Last Post: 07-31-2013, 05:36 PM
  3. mercruiser 4.3 with alpha-one water coming in from behind engine
    By rockbell in forum Mercruiser Sterndrive Forum
    Last Post: 02-01-2012, 09:06 AM
  4. Alpha Mercruiser water from the prop port how much should be coming
    By dyoungmc in forum Mercruiser Sterndrive Archive
    Last Post: 06-11-2007, 06:58 PM
  5. Loud squeaking noise 43 LX Mercruiser Alpha one
    By helicorp in forum Mercruiser Sterndrive Archive
    Last Post: 05-10-2007, 12:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
