Click for Chrysler parts and manuals!
Results 1 to 6 of 6
  1. #1
    Join Date
    Jun 2011
    Location
    New Rochelle, New York, United States
    Posts
    4
    Default Fogging a carb for winterizing
ID:	16513Where is the best spot to fog the carbs? Ive always just popped the flame arrestor off and sprayed the whole thing, I'm being told that's bad. Any thoughts? Thanks
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,881
    Default Re: Fogging a carb for winterizing
    Assuming you are refering to fogging the engine......throught the primaries bores (the side where the choke plate and idle mixture screws are.....
    Spraying into the secondaries won't hurt anything.....its just wasteful of the fogging agent as very little will enter the engine.....
  3. #3
    Join Date
    Jun 2011
    Location
    Posts
    4
    Yes, my apologies I don't know why I put carburetor, I meant fogging the engine.
  4. #4
    Join Date
    Jun 2011
    Location
    Posts
    4
ID:	16514Just to verify, we are talking about the circled bores for fogging the engine.
  5. #5
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,881
    yes, those are the primaries.....I prefer a spray can for each bore.
  6. #6
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,254
    Quote Originally Posted by Gregb5220 View Post
    First off....... you will not be Fogging the carburetor. You will be supplying the fogging solution into the cylinders.
    Secondly..... you have a dual plane intake manifold, which means that you MUST spray the fogging solution equally into both primary throttle bores.
    If we miss one plane..... we miss 4 cylinders (V-8 for example).
    Thirdly..... have a helper hold approx 1,200 RPM while you begin to fog.
    The helper will cut the ignition while you continue to apply the fogging solution until the rotating assembly comes to rest.
    In other words....... DO NOT allow the Fogging Solution to kill the Engine.
    YOUR helper will kill the engine by cutting the ignition. The helper will hold the throttle position as well.
    This way the fogging solution will not undergo combustion during the last few and critical revolutions.
    All of this will occur within 8 to 10 seconds..... there is no need to go any longer!
    That is the correct method for "Fogging" a carbureted engine.
    NOTE: We DO NOT Fog EFI engines! There is a different procedure for these engines.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
Similar Threads
  1. 1984 Johnson V6 - Winterizing / Fogging
    By Cascade Classic Outboards in forum Johnson Evinrude Outboard Forum
    Last Post: 11-21-2014, 01:03 AM
  2. oil in carb after un-winterizing???
    By neversinksmith in forum Mercury Mariner Outboard Forum
    Last Post: 06-03-2014, 07:41 AM
  3. Winterizing Fogging Question for 98 Four Stroke
    By krizm200 in forum Nissan Tohatsu Outboard Forum
    Last Post: 09-23-2009, 04:53 PM
  4. Fogging or Not
    By farnsp in forum Johnson Evinrude Outboard Archive
    Last Post: 06-14-2007, 08:31 PM
  5. Winterizing with OB equiped with FOGGING fitting
    By Bob Winkler in forum Archive 2003-2009
    Last Post: 11-10-2003, 10:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
