Click for Volvo Penta parts and manuals!
Results 1 to 3 of 3
  1. Default Compression test with carb removed; stopping gas from being pumped out line.
    I am about to do a compression test on my Volvo 3 liter. The engine has the manifold and carb off of it. I'm assuming that the fuel pump is going to be pumping fuel out of the fuel line when I turn the engine over for the test. Any advice on how to deal with this?
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,226
    Default Re: Compression test with carb removed; stopping gas from being pumped out line.
    Find a way to safely cap off the fuel line.
    The pump will think that the carburetor is full and will not receive any more fuel!
    As for the cylinder pressure test..... keep in mind that the instrument and attached hose may cause the pressure to become somewhat accumulative.
    In other words..... the first compression cycle may only partially pressurize the gauge due to the gauge's hose and the gauge's internal bourdon tube volume
    http://www.efunda.com/designstandard...rdon_intro.cfm
    This means that you must go through approx 3 full cycles (up to 7 revolutions) in order to obtain an accurate cylinder pressure reading!
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  3. #3
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,238
    Ayuh,.... Pull the line from the tank, off the fuel pump,...
Similar Threads
  1. Johson 1989 90hp fuel line placement after a vro has been removed.
    By Chazz T. Kirkham in forum Fuel / Oil Mixture Ratio
    Last Post: 06-15-2014, 03:08 PM
  2. Johnson starter motor removal. Two bolts removed, what's stopping me from removing it?
    By Cameron Russell Hoffman in forum Johnson Evinrude Outboard Forum
    Last Post: 03-29-2013, 04:59 PM
  3. Test running engine removed from boat
    By mpt in forum Volvo Penta Gas Engine Forum
    Last Post: 03-03-2011, 09:35 AM
  4. How do you do a compression test
    By jamiel in forum Johnson Evinrude Outboard Archive
    Last Post: 09-16-2008, 10:24 AM
  5. Compression test
    By merlin in forum Yamaha Outboard Archive
    Last Post: 08-01-2006, 10:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
