doakholman
I changed the plugs, points & condenser on my 1974 25 HP Johnson. Starts right up. Trolls great, idles perfectly. But if I run the engine wide open for longer than ~5 minutes then slow down I totally lose 1 cylinder. I set the points (per spec) at .022. Plugs (J4C's) gaped to spec .030.
Both ignition coils were new last year. Engine is cold (running in lake superior) but I checked the thermostat and it's working as expected. Leads (both cylinders) from armature plate to ignition coils are also new (this year).
While engine was sputtering I touched the bottom spark plug cap and got a little tickle but when I touched the top cylinder nothing.
Any ideas?
Any ideas?
