Click for Volvo Penta parts and manuals!
Results 1 to 4 of 4
Thread: Outdrive seals
  1. #1
    Join Date
    Mar 2010
    Location
    Brisbane, Queensland, Australia
    Posts
    9
    Red face Outdrive seals
    Hello from Brisbane (downunder).
    One of my two AQ 100B outdrive legs is leaking oil. I presume it is the seal located just to the rear of the propeller. I plan to change these on both legs. Would any knowing, kind soul know the part number for these and whereabouts I might obtain two? We will be in Seattle from 26 to 28 September, so that would be a convenient place, otherwise I can have them mailed to a friend in Wisconsin.
    Thanks. Bob
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,930
    Default Re: Outdrive seals
    part number 804209 two per drive. Good luck finding them all at the same place my guess is they are back to back seals.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    10,030
    They will be "industry standard" seals and will be Metric.
    Once out, you should be able to see the identifying numbers.... perhaps a P/N and the Metric dimensions.
    Example:
    This seal fits a 20mm shaft, a 28mm bore and is 4mm in thickness.
    https://i.ebayimg.com/thumbs/images/...PR5/s-l225.jpg
    A good bearing supplier will be able to bring them in...... or, you go directly to the supplier who would have them!
    The AFT-most seal (i.e., the water side seal) must be fully encapsulated (I.E., no exposed metal)
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  4. #4
    Join Date
    Mar 2010
    Location
    Posts
    9
    Thank you both. Helps me a lot. Regards, Bob
Similar Threads
  1. alpa 1 outdrive,oil leaking out weeping hole, bottom outdrive
    By mailman60 in forum Mercruiser Sterndrive Forum
    Last Post: 10-18-2015, 09:13 AM
  2. question about outdrive removal, 1985 mercruiser 5.7 with alpha outdrive
    By potatoe in forum Mercruiser Sterndrive Forum
    Last Post: 05-13-2013, 06:13 PM
  3. Alpha Gen 2 outdrive: Replacing upper gear case oil seals **REQUESTING ADVICE**
    By battleaxe99 in forum Mercruiser Sterndrive Forum
    Last Post: 02-14-2012, 10:02 PM
  4. Oil leaking from 270 outdrive new U joint and seals
    By overdrivegear in forum Volvo Penta Gas Archive
    Last Post: 05-26-2008, 09:15 PM
  5. Outdrive seals
    By bobtheboater in forum OMC Sterndrive and Inboard Archive
    Last Post: 04-07-2007, 10:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
