Click for Chrysler parts and manuals!
Results 1 to 2 of 2
  1. #1
    Default Velvet Drive Transmission Oil
    I have a 1969 Chrysler 318 engine with a velvet drive model AS1-71C. The dipstick says to use Type A oil. Can someone recommend what brand and type of oil to use? Also, I'm also trying to determine the oil capacity of the transmission. Thanks.
  2. #2
    Join Date
    Sep 2008
    Maryland - USA
    Default Re: Velvet Drive Transmission Oil
    The inline velvet drive gears work just fine with DEXTRON III. The BW service manual calls out Type C-3 oil.....and the Bulletin I have says even Type F is acceptable.....the big concern is not to intermix two unknown oil types.
    The capacity is not fixed but will vary with the application and installation. Two quarts should be adequate for a 71 unless the cooler lines have been lengthened...
Similar Threads
  1. Velvet Drive Transmission Heating up
    By Formula 41pc in forum Marine Transmissions and Reverse Gears
    Last Post: 08-13-2016, 12:31 AM
  2. velvet drive transmission
    By essikr in forum Marine Transmissions and Reverse Gears
    Last Post: 07-08-2014, 09:54 AM
  3. Velvet drive transmission
    By cal in forum Gray Marine Gas Engine Forum
    Last Post: 01-29-2007, 09:41 PM
  4. Velvet Drive Transmission problems
    By scott_duerring in forum Archive 2003-2007
    Last Post: 09-25-2006, 09:01 PM
  5. b72 velvet drive transmission
    By username in forum Archive 2002-2006
    Last Post: 05-03-2001, 09:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
