Trim and tilt non responsive
Bjmys
I have a Mercury XLSW 200 HP serial # 0T147100 outboard the trim and tilt worked when we stored the boat . I bought replacement batteries 2 installed them and have gotten light s and the bilge pump to run when I tried to raise the motor I got nothing, I went to the back motor and tried the trailer switch and got nothing again. Took a relay out and will replace them any suggestions boat sat 16 months covered in a storage yard!
Clean all connections of corrosion then remove the relays and do the same. LOWES or HOMEDEPOT sale electrical terminal spray for a couple $$$. Reconnect everything then try it. If same results replace relays (87-819590 or 8m0052578)
Same thing happened to me.. A local mechanic suggested that I Take a volt meter and test the wire to the trim motor. If you have juice to the trim motor, it's likely shot.
I had it replaced and it works like a gem...
