Results 1 to 7 of 7
    Default 1992 Alpha 1 knocking noise
    Hello,
    We just rebuilt out 1992 Alpha I Gen II motor (5.7L) and put a new water pump and oil in the out drive. All has been well until about 7 hours of operation the drive has developed a noise that sounds like someone is hitting it with a ball peen hammer at or very close to engine speed. It is not the deep down knock like comes from a rod bearing, but more than just a tap, tap, tap. We didn't pull the drive out yet, does anyone have a suggestion of what to look for first before pulling the drive? The drive is original, we replaced the water pump and changed the oil and that's it.
    Ideas?
    Thank you all very much!
    Kurt
    Calhoun, GA
    Jun 2006
    Spotswood, NJ, USA
    3,902
    Default Re: 1992 Alpha 1 knocking noise
    rocker arm noise, loose, broken, pulled stud, bent pushrod, broken spring
    Thanks, I am looking for causes of the noise from the out drive. That is where the noise comes from. The engine appears to run fine and is quiet.
    Jun 2006
    Spotswood, NJ, USA
    3,902
    a U joint getting ready to explode
    Sep 2010
    Jersey Shore
    4,697
    Before you pull the drive run it on the hose and determine if it is the upper or lower.
    Remove the drive and fire up the engine, see if the noise goes away. Just to confirm it is the drive.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  6. #6
    So you mean to just run the engine long enough to verify the noise is gone without fresh water, right?
  7. #7
    Sep 2010
    Jersey Shore
    4,697
    Quote Originally Posted by Kurt30701 View Post
    You can run it with out water to verify. No harm will be done. Keep it under 30 seconds at a time.
    Chris
    Jersey Shore.
  1. Mercruiser 470 knocking noise please help me !
    By [email protected] in forum Mercruiser Sterndrive Forum
    Last Post: 07-01-2017, 04:34 PM
  2. knocking noise 1984 140
    By eddiefitz in forum Mercruiser Sterndrive Forum
    Last Post: 05-19-2010, 10:54 PM
  3. Knocking noise
    By len doig in forum Mercury Mariner Outboard Archive
    Last Post: 08-31-2007, 04:25 AM
  4. Johnson 135 hp knocking noise
    By darren feener in forum Johnson Evinrude Outboard Archive
    Last Post: 08-04-2003, 08:17 PM
  5. Knocking noise what could it be
    By jason in forum Outboard motors archive 2000-2004
    Last Post: 07-23-2002, 09:32 AM
