Results 1 to 12 of 12
  1. #1
    Default Evinrude Overheating Issue
    Hey everyone, new here, hope you can help me out.
    Now I grew up working on 2-stroke motorcycles, and my Dad was a mechanic at a motorcycle/ATV shop for years.
    So not a novice to engines, and this has us stumped
    I picked up a 1991 25hp Evinrude, and I have not gotten it to run for more than 10 minutes at a crack yet.
    It overheats, and I can not figure it out.
    overboard indicator and water outlet both flowed
    1st try - check thermostat, stuck shut with a piece of gasket - test run overheat.
    2nd try replaced water pump - old was install wrong, that is where the gasket came from - test run overheat
    tried backflusing water thru the thermostat hole and it stopped flowing, hmmmm
    3rd try pulled the engine apart (covers) big glob of silicone in the water jacket around the cylinders - bingo!
    cleaned it out, - test run overheat! - but I noticed this time that a lot of water was bubbling out the lower unit holes.
    Pulled the power head again, checked the water inlet tube going into the head, and it was silicone in place with o-rings and all messed up.
    Got that all cleaned up, and replaced seals etc. - water flows even better now - and OVERHEATS!!!!
    I have torn the covers off again, can not find any blockage.
    Compression on both cylinders is 100psi, it starts on the 1 or 2 pulls, and runs great until it warms up, so I don't think it is engine mechanica, I think it has to be water flow. - and yes the new t-stat opens in 150deg water.
    And my heat gun verifies the motor is getting hot 400deg+ on the head, so it is not a bad overheat switch.
    Any help is appreciated.
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Default Re: Evinrude Overheating Issue
    Are the 3 water diverters in place ?
  3. #3
    Quote Originally Posted by racerone View Post
    Can you expand on that?
    From the exploded diagrams I think I have everything.
    model number is E25RLEIE
  4. #4
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,329
    Whoever had that engine prior to you and was equipped with an excessive amount of silicone has the intelligence of a rock! Silicone has no place whatsoever on that engine. I'm afraid that you have a never ending job of clearing that junk out of the engine unless you tear it down completely to knowingly have all water passageways cleared.
    I can only imagine what else he has screwed up that you'll encounter in the future. My apologies to come across so pessimistic but morons and idiots (some are both) should be barred from having tools.
    We occasionally have questions. If you fail to answer, it may affect ours.
  5. #5
    I hear you there, step 3 I tore off every cover I could, and it all looks clean, yesterday I was spraying break cleaner thru the water passages tracing the path, and can not find any blockages
  6. #6
    Alright, looking at the diagram i do not have #8 & #9
    http://www.marineengine.com/parts/jo...p%3B+Crankcase
    but you said 3 diverters, where is #3?
  7. #7
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    ???-------Does it say 2 required for # 8 ?
  8. #8
    Yeah I see that - but the picture only shows 1...
  9. #9
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Ohwell,----2 +1 makes 3 in my skule book.
  10. #10
    Now does someone have a picture or description of how these are installed?
    Google search turned up very little detail.
    Don't have the engine in front of me, but I am thinking since it was not obvious they were missing, it probably is not obvious how they are to be installed.
    Join Date
    Apr 2010
    Posts
    4,140
    It shows them in the factory service manual.........
  12. #12
    Try 1 I found out you can not get the water tube lined up without pulling the lower unit (just putting the power head in), at least I didn't as evident from lack of water flow when I started it.
    However once I corrected that it ran for a test run longer than I have had it running to date - combined.
    So I am cautiously hopeful.
    Thanks!
Similar Threads
  1. overheating issue
    By mreider in forum Mercury Mariner Outboard Forum
    Last Post: 07-02-2015, 10:30 AM
  2. 3.0 L Overheating issue
    By Jason Campbell in forum Mercruiser Sterndrive Forum
    Last Post: 06-10-2012, 04:43 PM
  3. 3.0L OMC overheating issue
    By Ryanscolo in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-11-2010, 07:39 PM
  4. b81 Evinrude 70hp Center Cylinder Overheating Issue
    By davegran in forum Johnson Evinrude Outboard Archive
    Last Post: 07-27-2007, 10:43 AM
  5. 83 260 HP Overheating Issue
    By sr_245 in forum Mercruiser Sterndrive Archive
    Last Post: 07-04-2007, 07:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
