Click for Honda Manuals, Parts and Model Guides!
Results 1 to 6 of 6
  1. #1
    Default Idle Adjustment 2006 9.9 Remote
    Hello
    What is the correct way to adjust the idle on my 9.9 Honda (remote cable)? It starts and runs at an RPM too fast to shift. It's on a 2010 Hewes 1800. Was doing good when I parked it (covered in carport) in 2015 but on firing it up today I can't get it to idle unless I physically pull back on the cable linkage. Cable linkage seems smooth. Never used alcohol added gas prior to parking. I could add a spring at the carburetor but would rather "fix" it right.
    Thanks,
    Mark
  2. #2
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,864
    Default Re: Idle Adjustment 2006 9.9 Remote
    If it responds by pulling on the cable, then it's not a gas or internal to the carburetor problem. It likely just needs lube somewhere. Either in the shift console itself or where cable exits the housing under the hood. I wouldn't suspect the linkage at the carburetor right off the bat unless you see that the spring is broken.
    You might try taking the cable off of the carb and see how it starts and idles. It SHOULD have an elevated idle when cold and start slowing to around 950 rpm in about 1 minute or so.
    If that's how it operates with the cable uncoupled at carb then you know it's not the carb and you need to concentrate on the cable and console.
    I have had a sticky cable fool me more than once. They feel "smooth enough" but they stick just enough to cause problems. Typically a new cable is required for trouble free operation if that's what's happening.
    Good luck
  3. #3
    Join Date
    Mar 2009
    Location
    Cincinnati, OH USA
    Posts
    4,372
    Jimmy is correct.
    If it idles ok when you disconnect the cable, you might also just have a slight kink in the cable (from engine being tilted or cables stepped on) and it does not allow the cable to move as it should....or....
    the linkages might have gotten worn or the cable is stretched.
    You might be able to solve the issue, at least temporarily, by turning the cable end connector out a turn or two to allow the cable to extend all the way to allow the motor to idle.
    If the cable is sticking, then as Jimmy said, the cable may need to eventually be replaced. When you do that, I always recommend that both cables be changed. It is only a few more minutes of work in addition to the cost of one other cable.
    Mike
  4. #4
    Thanks folks. I appreciate the guidance and will let you know the results. This is a great forum.
    Mark
  5. #5
    Yep. With the cable disconnected she idled as she should. I adjusted the cable a couple of turns, lubricated the cable a bit, exercised the controls a bit and it's back to normal.
    Thanks,
    Mark
  6. #6
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,864
    Great!
    Glad you got it sorted.
    Happy boating.
Similar Threads
  1. Tohatsu Remote Control Throttle design/ adjustment/ wear/ maintenance ?
    By preventec47 in forum Nissan Tohatsu Outboard Forum
    Last Post: 09-01-2017, 08:31 AM
  2. 2006 15 HP Idle adjustment
    By cleco in forum Yamaha Outboard Forum
    Last Post: 07-17-2016, 06:21 PM
  3. 2006 mercury 15hp serial#1B367866 valve adjustment procedure - HELP !!!!
    By mtnbowhunter in forum Mercury Mariner Outboard Forum
    Last Post: 05-25-2016, 12:15 AM
  4. 2006 Mercury 25hp (usa model No 1B301794) tiller control to Remote.
    By CliveB in forum Identifying Model / Year / Horsepower
    Last Post: 12-19-2014, 10:55 PM
  5. Idle/throttle adjustment for bf50a '2006 50 hp
    By groove508 in forum Honda Outboard Forum
    Last Post: 04-17-2010, 09:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
