Click for Honda Manuals, Parts and Model Guides!
Results 1 to 4 of 4
  1. #1
    Default Honda BF30 Outboard but generally any Outboard
    Hi All (first post)
    I don't see any cooling water exiting the engine - does it exit above or below the waterline? (Above I thought) I can see two grilles just above the propeller (under the waterline) which I assume are the intakes and they 'look' clear of debris but it seems I will have to get in the water to service these.
    If I take the engine upto about 3000rpm briefly then lots of 'air' exit the aforementioned 'intake' grills....
    Whats going on ......
    Thanks guys....
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,144
    Default Re: Honda BF30 Outboard but generally any Outboard
    Well, you should not be running any outboard without a water supply to the water pump.--------If you did that you now need a new pump kit.------------The tell tale abiove the water is merely an indication that the pump is working.------------95 % of the water exits out the prop with the exhaust.
  3. #3
    Quote Originally Posted by racerone View Post
    Hi
    The boat and outboard are in the water - just that there is no indication of water flow apart from these 'bubbles' at a high rpm - should there be water exiting this 'tell-tale' - presumably above the waterline?
  4. #4
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,755
    Yes, on most Hondas, the tell tale nozzle is located on the starboard side of the engine case just below the flange that the removable hood sits on and slightly to the rear. If you can't find it there, look on the opposite side.
    Sometimes the the plastic tube or, the fitting that the tube attaches to on the engine block, get plugged with debris and need to be cleared. Sometimes a piece of wire or weed eater line will help to clear it.
    But, if your pump isn't working, no amount of "probing" will help and the pump will need replacing. The lower half of the outboard will have to come off for that chore so the outboard will need to be out of the water.
    Some replace their pump impeller every year, as the book recommends. I do mine every other season.
    Good luck and ask all the questions you want to. That's why we're all here.
Similar Threads
  1. Honda BF30 Oil Leak - Any ideas or suggestions?
    By SinkTip123 in forum Honda Outboard Forum
    Last Post: 08-31-2014, 10:11 PM
  2. Honda BF30 Rattling Noise From Shift Linkage
    Last Post: 08-05-2014, 02:41 AM
  3. Honda Gearshift for BF30
    By gordo50 in forum Honda Outboard Forum
    Last Post: 08-15-2011, 06:05 PM
  4. Anyone have an online Honda BF30 Shop Manual?
    By guyhammer in forum Honda Outboard Forum
    Last Post: 04-22-2010, 11:18 AM
  5. Honda BF30 hard start when cold
    By guideya in forum Honda Outboard Archive
    Last Post: 05-11-2009, 05:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
