Results 1 to 6 of 6
  1. #1
    Default Help identify distributor (pics) for Mercruiser 5.7L competition ski motor
    Hey all. I recently bought a 1990 Sanger Ski boat with a Mercruiser 5.7L inboard direct drive motor. According to the motor serial (0C771828) the engine's model # is 3579111CS.
    I thought I had the Mallory distributor so I ordered Pertronix electronic ignition kit part # MC-181 to replace the points. However, it does not appear to be the right kit after diving in to do the swap.
    I can't figure out which distributor I have as there does not appear to be any identifying marks on it anywhere other than the SAE decal. Can any of you help identify which distributor this is and perhaps even which Pertronix kit I would need?
ID:	16496Click image for larger version.
ID:	16497Click image for larger version.
ID:	16498Click image for larger version.
ID:	16499Click image for larger version.
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,838
    Default Re: Help identify distributor (pics) for Mercruiser 5.7L competition ski motor
    It is a Mallory and I would not convert it. Install the Delco EST setup yo will be much happier.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  3. #3
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,198
    keep the points, they will make spark under the worst of conditions
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,814
    That is an old Mallory YL unit! It's painted black like what Merc did years ago.
    I would not convert using the Pertronix junk!!!!
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  5. #5
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,743
    I agree what is the reason your getting rid of the points? Set the points using a dwell meter and check the progressive spark advance. If it is within spec run with it.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  6. #6
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,556
    Most reliable, easy to fix (out THERE) system ever devised.
    Jeff
Similar Threads
  1. 1978 mercruiser 120 hp gear oil leaking behind prop, pics included
    By Robert Shackleferd in forum Mercruiser Sterndrive Forum
    Last Post: 08-06-2014, 11:42 PM
  2. Can anyone identify my make and model just from pics
    By dejay706 in forum Yamaha Outboard Forum
    Last Post: 01-24-2012, 12:03 AM
  3. Mercury Motor Pics
    By planomark in forum Mercury Mariner Outboard Archive
    Last Post: 04-04-2009, 11:26 AM
  4. PICs What year is this motor
    By rookie_on_the_water in forum Johnson Evinrude Outboard Archive
    Last Post: 06-25-2008, 12:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
