Results 1 to 13 of 13
  1. #1
    Default Is it worth it to swap out OMC to Mercruiser?
    Hey Boaters,
    I have a 88 Galaxie Boat works with and OMC 350 motor. I looking to possibly swap out the OMC stuff and go Mercruiser. I have no plans on selling the boat for at least 3 to 5 years. A good fellow boater friend of mine told me that finding OMC parts are just terrible to find. So my question is. Is it worth it to swap out my OMC and go mercruiser? Or should I just keep what I have for now. My current motor is running just fine other than some issues with the OMC wiring harness that loves to cut my power off to my boat at times, very irritating. I realize that everything is running fine now which is why I think it may be a good time to sell my OMC stuff off. But not sure if I would really get anything for it other than the Chevy 350 motor. If I do plan on selling my boat in the future, I'm thinking mercruiser internals would have more value then OMC. So your thoughts would be great. As far as labor cost If I did swap out motor and drive I would more than likely do it myself.
    Thx
    Chris
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    5,006
    Default Re: Is it worth it to swap out OMC to Mercruiser?
    If you like the boat and plan on keeping it, eventually you will have to replace the drive. When that time comes repower Mercruiser. You can probably find a donor boat with a Newer Mercruiser set up. I would find a Bravo Drive Donor.
    No matter what you spend on this, you will never get your money back.....it's a 1988 Galaxie.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  3. #3
    Yea I figured. So rather I keep it an OMC or swap a nice mercruiser in it, the 1988 is gonna hurt me? If that's the case then maybe I should move to whole thing now. Or just leave it alone.
    Chris
  4. #4
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,316
    Just an opinion - I'm with Chris on this one. An 88 Galaxie is not worth much in any case, so keeping the OMC vs. installing a Merc is not going to make a lot of difference in re-sale value. If you plan to use that boat a lot over the next 3 - 5 years, then the Merc may make since IF you can find a cheap donor boat with a good engine and out drive. But that is always problematic - a used motor and out drive is just that, and you typically have no idea what real condition they're in. I think you need to simply make up your mind just when you are going to do a trade-up, and let that be your guide as to how long you're going to keep this boat in it's current state.
    CHawk 25 DLX
  5. #5
    Chawk
    thx for the reply! If going with Marc is not gonna increase resale then maybe there's no reason to spend the money. Maybe pull the motor out when it goes and do a nice rebuild and call it a day. Would it be benificial to at least swap out the Outdrive with a mercruiser alpha 1?
    chris
  6. #6
    Join Date
    Sep 2008
    Location
    Posts
    4,316
    Chris is more knowledgeable about those out drives than I am. My only experience has been with Volvo's.
    CHawk 25 DLX
  7. #7
    OK thank you very much for the information!
    Chris
  8. #8
    Join Date
    Oct 2017
    Location
    Seattle
    Posts
    4
    Sorry to use harsh language here... don't mean to offend anyone, but the common OMC stern drives are junk. I grew up on Lake Michigan and I saw SO many OMC stern drive failures. The other guys are right, while a Alpha or Bravo would be nice, the hole in the transom is a different size and you get into a fairly serious conversion. My recommendation is that you get a different boat, or learn to rebuild your OMC and tear it down every year to inspect. You won't believe how cheezy the parts are. OMC made the Cobra and I think it is better, but I've never seen one taken apart.
  9. #9
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,579
    Nope,... Not really,... hookin' an OMC motor to a Merc drive is nearly impossible,....
    A pulleys to prop swap is the only swap that makes sense,....
    The flywheel housin' is different,...
    The exhaust is different, 'n different diameter,...
    Only the Long Block is easily swapable,....
    'n as noted above, unless ya got a hull that has a cult like followin', it ain't worth the money,....
    I've done several Hi-Liners, as they can bring 20 grand or more when properly refitted,...
    I'm doin an Old Town Atlantis right now, that should turn a $3500. ole hull, into a $30,000. refit boat when done,....
  10. #10
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    3,053
    You can get a SEI conversion kit and it works great!!!!
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  11. #11
    Quote Originally Posted by faztbullet View Post
    Who sells those??
  12. #12
    Join Date
    Dec 2006
    Location
    Posts
    5,579
    Ayuh,... iboats sells 'em, or you can go factory direct,... just google 'em,....Sterndrive Engineering Industries,....
  13. #13
    Thank you Bondo!!
Similar Threads
  1. 1978 Mercruiser 470 worth?
    By DKaiser in forum Mercruiser Sterndrive Forum
    Last Post: 07-07-2016, 07:59 AM
  2. engine swap 260 mercruiser to 228 mercruiser questions
    By jfowler502 in forum Mercruiser Sterndrive Forum
    Last Post: 05-21-2011, 09:23 AM
  3. Is worth it to swap
    By jjdluz in forum Yamaha Outboard Archive
    Last Post: 10-29-2008, 04:50 PM
  4. 2003 150 efi worth it to swap
    Last Post: 07-28-2008, 06:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
