Results 1 to 6 of 6
  1. #1
    Default Korky in MN - Mercruiser miss
    1986 (approx) Four Winns
    Mercruiser MCM 140 #A676736 (from engine placard), 4 cylinder
    3.0L (assumed)
    PROBLEM
    After cruising for a short time, the engine develops a “hardmiss” which is persistent once the engine is hot. The tach confirms RPMfluctuation. Must throttle back and can only idle after the miss hasdeveloped. Once the engine is turned off and has cooled, then it’spossible to cruise again for a short time before the engine warms up and the“miss” returns.
    Ignition problem? Fuel problem?
    The following were changed May, 2017:
    34235 breaker
    33662 condenser
    18-5418 rotor
    18-5385 cap
    RV9YC plugs
    Ignition?
    Replace the ignition coil and spark plug wires?
    Fuel?
    Replace fuel filter in fuel pump? Replace any otherfilters or screens in the fuel line and carburetor? Gaskets?
    I don't have a lot of high tech testingequipment. Can you help me out with an educated guess on this problem?
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,198
    Default Re: Korky in MN - Mercruiser miss
    what do the spark plug tips look like ?
  3. #3
    Excellent. New plugs installed. Problem continued. Re-installed old plugs. Problem continued.
    Dont think the plugs are suspect.
    I plan to change the ignition coil and plug wires next.
    Thoughts?
  4. #4
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,198
    What color are the tips? They can tell if its a lean condition, or a too rich condition, or just right condition.
    Blister white could mean water ingestion . If color is correct then suspect the wires or the coil
  5. #5
    Quote Originally Posted by Bt Doctur View Post
    THANK YOU. That's kinda what I figured to do next.
  6. #6
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,796
    Also I would remove distributor cap and see if shaft moves side to side.
    One issue of this design (also the inline six cylinder) is the distributor shaft bushings wear egg shaped due to distributor being on angle.
    Also confirm mechanical advance mechanism under point plate is moving freely and fully. Not all rusted or frozen.
    Jack
    Northborough Ma
    Helping others sometimes with an attitude....haha..
Similar Threads
  1. 3.0 with a miss on Cyl #3
    By rhays in forum Mercruiser Sterndrive Forum
    Last Post: 09-04-2014, 08:54 PM
  2. miss
    By Wayne Mckenney in forum Johnson Evinrude Outboard Forum
    Last Post: 03-15-2014, 05:23 PM
  3. 1998 7.4 L mercruiser engine miss
    By charlie young in forum Mercruiser Sterndrive Forum
    Last Post: 03-30-2011, 10:54 AM
  4. Mercruiser 140 Miss Fire
    By nic_surry in forum Mercruiser Sterndrive Archive
    Last Post: 07-12-2007, 04:26 AM
  5. Miss
    By artmiller in forum Johnson Evinrude Outboard Archive
    Last Post: 03-18-2006, 11:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
