Click for Volvo Penta parts and manuals!
Results 1 to 8 of 8
  1. #1
    Default AQ 280 Exhaust Bellows Replacement - Part Number Conflict
    Hello,
    Need to replace the exhaust bellows on my 1978 model AQ280. Stamped number on the current rotten bellows is "Volvo 897631". Yesterday I picked up a new-in-box VP kit from a supplier near Seattle. The kit box is stamped "Kit VOP 876631". Additionally the box label lists the bellows as VOP 872984 with an additional sticker 876631. The new bellows in the box is stamped "Volvo 872974".
    The replacement bellows is obviously made of heavier material than the original, has the wire rings in each of the nine bellows grooves (the original only has rings in 3 grooves). The original has a drain port. The replacement does not have an obvious drain port.
    Is the replacement bellow I bought the correct one even if the numbers don't match?
    Thanks,
    Mark
  2. #2
    Default Re: AQ 280 Exhaust Bellows Replacement - Part Number Conflict
    Pictures old and new bellows. New bellows much thicker and harder sides and has a wire ring in each groove.Click image for larger version.
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,650
    Look closer there must be a hole. It looks like it will fit as long as the holes are the same size and fits in the groove on both sides with the hole pointing down.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,698
    Most all of the AQ series exhaust bellows will interchange. However....... what differs will be the internal "back-flow-prevention-flapper" -vs- no internal flapper.
    (the internal flapper is restrictive)
    But let's back up:
    What engine model do you own?
    What lower drive unit model do you own?
    Does the lower drive unit offer back-flow-prevention?
    The V-8 engines do not like the internal "back-flow-prevention-flapper"..... too restrictive!!!!!
    The exhaust outlet located flapper is much less restrictive....... plus it is openly visible for routine inspection.
    If you have a 280 drive ("back-flow-prevention-flapper" on some production models ONLY), with a small amount of work, you can retro-fit a 290 "back-flow-prevention-flapper" .
    Also..... I do have a good 280 production model flapper that I would be willing to sell.
    Tip: store your boat with the stern drive fully down and aiming straight forward.
    this will extend the life of both universal drive shaft bellows AND exhaust bellows!
    Shown below is the very rare, production model ONLY, 1 pc 280 back-flow-prevention flapper. This part was never available over the counter!
    With a small amount of work, the 290 flapper can be made to work.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Exhaust outlet 280 and 290 lower.jpg
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  5. #5
    The engine is a VP170. The outdrive is a AQ280. The boat is a 1978 Glasply. There is no back flow preventer on the outdrive or the bellows. Theprevious owner bolted on a piece of rubber on the exhaust port but it does not function to prevent back flow.
    What's the downside to operating without a back flow preventer.
    Thanks,
    Mark
  6. #6
    What appears to be a modified back flow preventer is bolted to the exhaust port and is not hinged and is only slightly flexible (picture attached). I guess I don't see the purpose of this setup. I had older fiberform a couple of years ago with a 270 outdrive. That outdrive had an actual hinged flapper that could cover the exhaust port.
    I guess the bottom line is -- should I return the bellows I picked up yesterday and try to get a bellows with a built-in back flow preventer. The engine is an in-line 6 cylinder so exhaust restriction is not a issue (if I understand your previous message correctly). Or should I buy your "280 production model flapper"? Where are you located?
    Thanks,
    Mark
  7. #7
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,698
    Quote Originally Posted by shadetreevet View Post
    That would an AQ170 w/ 280 stern drive!
    There is no back flow preventer on the outdrive or the bellows. The previous owner bolted on a piece of rubber on the exhaust port but it does not function to prevent back flow.
    What I see in the photo looks to be an actual and rare 280 production model back-flow-prevention-flapper.
    It appears to have been over-heated........ and it looks as though it is done!
    What's the downside to operating without a back flow prevention flapper?
    The down side would be water entering an open exhaust valve.
    This could occur from exhaust gas reversion, or during a quick and while-moving shut-down, or from a wave surge from another boat, or from several other unwanted situations.
    When water enters an open exhaust port, the valve is cooled quickly, often distorting the valve causing the need to remove the cylinder head, etc.
    In an extreme scenario, you may end up with even further damage.
    Thanks,
    Mark
    Thanks,
    Mark
    As said earlier...... I think that the exhaust bellows with the internal flapper creates a restriction.
    The easily available 290 flapper can be purchased over the counter, and can be retro-fit to your 280 with a small amount of work!
    The 280 flapper that I have needs to be removed from the case it's attached to ....... but I'd do that if it would help you! Six SS pop-rivets and you'd be back in business!!!!!!
    Rick east of Portland OR.
    Portland, Oregon
  8. #8
    Hi Rickm
    When would your 280 flapper be available and how much do you want for it?
    Thanks,
    Mark
Similar Threads
  1. Part number needed for Alpha 1 Gen 2 exhaust "tube"
    By david_ray in forum Mercruiser Sterndrive Forum
    Last Post: 04-08-2016, 10:25 PM
  2. 454xl fuel pump replacement part number
    By kevin_z in forum Crusader Marine Engine Forum
    Last Post: 03-29-2016, 10:16 AM
  3. replacement of exhaust bellows
    By turbot660 in forum Mercruiser Sterndrive Forum
    Last Post: 07-22-2015, 09:29 PM
  4. Replies: 6
    Last Post: 12-26-2014, 07:41 PM
  5. Merc 470 Exhaust elbow bad and 2 different part numbers for replacement
    By crkpot in forum Mercruiser Sterndrive Forum
    Last Post: 07-28-2014, 10:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
