Results 1 to 4 of 4
    Jan 2017
    Salem Oregon
    81
    Default ignition coil, Diamond E-035, common part number?
    does anyone know what the common part number for the diamond ignition coil is... the diamond number is E-035 and the sierra number is 18-5437, but none of the local parts places recognize either of these numbers, so they cant cross them...
    the correct OMC numbers (383444 and 378231) cross over to a delco U-505, but this is WRONG because it is a resisted coil.....
    I need a NON resisted coil of the correct ohms for the BID system on my boat, but I dont know what the ohms of the coil are supposed to be....
    thanks
    Jan 2017
    Salem Oregon
    81
    Default Re: ignition coil, Diamond E-035, common part number?
    UPDATE... I found what I was looking for.
    the Prestolite distributor with the BID system (breakerless ignition) will use a 1.5ohm ignition coil, without a resistor in the system.... some coils, such as the OEM diamond E-035 (which I have found is a 1.5ohm coil) will have instructions that say to use the coil with an external ballast resistor, but the prestolite BID does not require a ballast resistor when a 1.5ohm coil is used.
    when the prestolite BID was still being manufactured, it was recommended to replace the OEM coil with a prestolite 5-69 coil... which was simply a 1.5ohm "black can" coil. (no longer being manufactured)
    the recommended replacement is a 1.5ohm Pertronix or MSD coil, which are still being manufactured.
    NOTE; external ballast resistors were used with the diamond E-035 on breaker point ignitions.
    Dec 2015
    maplevalley WA
    4,645
    You can use a points type coil just add a ballast resistor. Check that coil shortly after starting the engine if the coil gets hot to the touch just put a ballast resistor to coil pos and call it good.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
    Jan 2017
    Salem Oregon
    81
    Quote Originally Posted by kimcrwbr1 View Post
    not in this case... the instructions that were included with the BID module kits, for those that wanted to upgrade from points to the Breakerless Ignition Distributor system, the instructions stated specifically, if there is a ballast resistor in the system, remove it from the system or bypass it when using the BID module as it was designed to be used directly with the 1.5ohm standard OEM coil .
    the only reason that a ballast resistor may be needed with the module is if the system has been modified and a low resistance coil installed.
  1. OMC Coil part number 582995
    By Blueghost in forum Johnson Evinrude Outboard Forum
    Last Post: 07-13-2017, 10:18 PM
  2. mercury 2.2hp ignition coil. Part # 95242T. - 95242, question.
    By Patrick Maloney in forum Mercury Mariner Outboard Forum
    Last Post: 07-22-2015, 12:09 PM
  3. '78 LM318 Electronic Ignition Coil Part #????
    By Dollarbill in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 09-03-2010, 04:41 PM
  4. 1979 35hp part number for ignition key
    By classicgen in forum Johnson Evinrude Outboard Archive
    Last Post: 10-12-2009, 07:46 AM
  5. Need part number for ignition switch 1995 48hp
    By Morten Ringvold in forum Johnson Evinrude Outboard Archive
    Last Post: 12-31-1969, 07:00 PM
