Click for Honda Manuals, Parts and Model Guides!
Results 1 to 9 of 9
  1. #1
    Default 2007 honda 15hp manual start
    I was checking the oil on my 2007 honda 15hp outboard the other day and found this laying in the bottom of the motor , cant seem to see where it goes can anyone help me out on this ? Its about a 1 inch round concave steel mesh piece , i cant fiqure out how to post pic !
  2. #2
    Join Date
    Mar 2009
    Location
    Cincinnati, OH USA
    Posts
    4,390
    Default Re: 2007 honda 15hp manual start
    I think you are talking about part #1. http://www.boats.net/parts/search/Ho...VER/parts.html
    If you try to put it back in, you might have to take a soldering gun and melt some of the plastic around it to keep it in.
    Mike
  3. #3
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,907
    They all fall out eventually from vibration wearing away the keeper tabs. You can try Mike's method or mine if you like it.
    I've done a bunch by using a #4 or #6 sheet metal screw to "wedge" it in place and keep it there.
    Hang the mesh back in it's spot and then screw the sheet metal screw into case at the bottom of the mesh ring at a 45 degree downward angle. This sort of wedges the screen in place.
    You don't really want to use glue or silicon because the crankcase vent delivers oil and gas vapors to the box and those will break adhesives down quickly.
    If you come up with an ingenious method for doing this chore, let us know.
    Oh, and you could buy a new muffler box with a new screen and tabs but way more Cocos and vibration will have that one worn down too eventually.
    Good luck.
  4. #4
    [QUOTE=jgmo;588390]They all fall out eventually from vibration wearing away the keeper tabs. You can try Mike's method or mine if you like it.
    That is the part im talking about , thanks fellas
  5. #5
    Will it hurt to run it without it until i get a chance to fix it ?
  6. #6
    Join Date
    Mar 2009
    Location
    Cincinnati, OH USA
    Posts
    4,390
    No.
    Mike
  7. #7
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,907
    Not at all. You've BEEN running it without it for some time I suspect.
  8. #8
    Thanks again guys !
  9. #9
    Anpther question since this is my first 4 stroke motor, i do alot of duck hunting and hunt in some very cold weather , how do they do in these conditions , it seems a little cold blooded now when its warm out ? Just asking ??
Similar Threads
  1. 1986 Johnson 15hp Tiller Control Manual Start
    By EvansSJ in forum Johnson Evinrude Outboard Forum
    Last Post: 09-22-2016, 02:30 AM
  2. 2007 Honda 15hp Ive got mayo in my crankcase, Starting issues
    By Merc4me in forum Honda Outboard Forum
    Last Post: 04-25-2013, 11:28 AM
  3. Convert 15HP Honda 4 stroke to electric start.
    By Whidbeyfisher in forum Honda Outboard Forum
    Last Post: 08-17-2011, 10:06 AM
  4. struggling with '75 15hp manual start
    By dawnfogg in forum Johnson Evinrude Outboard Forum
    Last Post: 08-05-2010, 05:42 PM
  5. Repar manual for 2001 Honda 15hp fourstroke
    By hobbs28 in forum Suzuki Outboard Archive
    Last Post: 04-18-2004, 10:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
