Results 1 to 7 of 7
  1. #1
    Default 5.0 lx 1988 thermostat housing?
    i am confused on which thermostat housing ,i should have,currently i have thermostat that has 4 outlets ,no check ball set up,please see photos i have middle riser that they have plugged the water inlet ,my problem is the port side riser not getting much water is that because i should have thermostat housing that hoses go to riser with or without check balls my model shows 3 different version of raw water cooling which one is correct for my motor 1988 5.0lx /alpha1 gen 1 outdrive
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	16483   Click image for larger version.
Name:	what style.jpg
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,891
    Default Re: 5.0 lx 1988 thermostat housing?
    No, the current setup is fine with the hoses going to the bottom of the manifolds. For weak/low flow always start at the impeller
  3. #3
    ok thank you bt doctur ,as always appreciate it
  4. #4
    will an automotive hose make a difference with flow
  5. #5
    i get good flow starboard side ,but not as much on port side
  6. #6
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,292
    That's usually a sign that the riser's water outlet (where water and exhaust finally meet) is plugged. The hot side riser needs to be removed and rodded out with a coat hanger stuck in a drill. Stick a water hose in there and make sure it's flowing nicely.
    Jeff
  7. #7
    thanx fast jeff gonna take off tonight we shall soon see whats going on there , I like the coat hanger in drill, idea
Similar Threads
  1. Thermostat housing leak
    By bobct in forum Crusader Marine Engine Forum
    Last Post: 04-30-2014, 02:32 PM
  2. Thermostat Housing
    By da2434890 in forum Marine Power Engine Forum
    Last Post: 11-14-2011, 10:20 PM
  3. Universal M12 Thermostat Housing
    By stgermain45 in forum Universal and Westerbeke
    Last Post: 05-20-2011, 01:47 PM
  4. 4154 thermostat housing
    By crzhors in forum Perkins
    Last Post: 09-28-2009, 09:08 AM
  5. Thermostat And Housing
    By edloh in forum Outboard motors archive 2000-2004
    Last Post: 02-06-2002, 09:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
