Results 1 to 5 of 5
  1. #1
    Post Yamaha 25hp 4 stroke bogging down
    My engine starts great and runs at idle speed but bogges down on open throttle. Have replaced fuel filter and tank. Fresh gas (93 octane). Rebuilt the carburetor and still having issues. Any help for me?
  2. #2
    Default Re: Yamaha 25hp 4 stroke bogging down
    Did you check the spark and compression? Also need to check the fuel lines. Check all lines for leaks. Check the fuel pump and fuel pressure to. Did you sync the carbs after rebuilding?
  3. #3
    Quote Originally Posted by SaltyDog727 View Post
    I have not messed with it this winter. I found out that if I held my hand over the carb intake, it ran fine. Not sure what that does to cause it run ok.
  4. #4
    How was the carburetor cleaned?
    A motor bogging down in usually indicative of insufficient gasoline. Trying misting a bit of gasoline into the air intake just about the time that it would start to bog down. If it picks up and runs that is telling you that the carburetor is not doing its job.
  5. #5
    Quote Originally Posted by boscoe View Post
    Ok, thanks
Similar Threads
  1. 2008 Yamaha 8hp 4 stroke bogging at high speed
    By Euphoria in forum Yamaha Outboard Forum
    Last Post: 08-12-2013, 06:45 AM
  2. 04' 90 Horse 2 Stroke Yamaha bogging down
    By Almazur in forum Yamaha Outboard Forum
    Last Post: 10-07-2012, 07:11 PM
  3. yamaha 25Hp 2002 4 stroke
    By brotatochip in forum Yamaha Outboard Forum
    Last Post: 01-11-2012, 05:23 PM
  4. 2004 Yamaha 2 stroke 25hp
    By guido2 in forum Yamaha Outboard Forum
    Last Post: 08-31-2011, 10:50 PM
  5. 2004 25 HP Yamaha 2 stroke bogging down
    By geoffreyreuland in forum Yamaha Outboard Archive
    Last Post: 10-13-2007, 12:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
