Results 1 to 15 of 15
  1. #1
    Join Date
    Apr 2006
    Location
    Posts
    234
    Default 2003 Bravo 3 Drive - Using Oil
    2003 Bravo 3 drive w/850 hours has started to use oil. The drive has always had oil changed at end of each season, the exterior is mint even though she's in the Brine for (7) months a year. Over the years, she has used varying amounts of oil at weird intervals - but this year its been more consistent.
    I have never changed any seals ( except for filler / breather washers and have never had water in the gear oil after each season.
    I do not see any leak indications at or leading from the drive oil receptacle to the drive.
    I don't see any oil leak indication in the water near the drive.
    I believe I have the tools to do a pressure and vacuum test and plan to do one at the close of the season.
    Are there seals that I should change either way ?
    Any thoughts on this ?
  2. #2
    Join Date
    Nov 2005
    Location
    Mt. Zion, Illinois,
    Posts
    627
    Default Re: 2003 Bravo 3 Drive - Using Oil
    My boat has an Alpha One so I don't know if the same applies to Bravo. Last year I started to mysteriously lose gear oil from my reservoir and had to top it off every couple of outings. There were no leaks around seals or anywhere else. In the winter we finally removed the outdrive and found a plastic fitting in the gimbal housing was cracked and was leaking.
    KJ
  3. #3
    Join Date
    Apr 2006
    Location
    Posts
    234
    Not sure of the similarities / differences between the two in terms of the oil reservoir connections from reservoir to the drive... What did that plastic piece do ? Where was it connected to ? Was there oil in your bellows ?
    My transom plate, gimbal and swivel were all replaced (2) years ago... Could be something is wrong there, but it wouldn't be from age...
  4. #4
    Join Date
    Nov 2005
    Location
    Mt. Zion, Illinois,
    Posts
    627
    Quote Originally Posted by abl1111 View Post
    The plastic fitting was a small hose barb that threads into the outdrive. A short piece of tubing connected between the outdrive and gimbal housing and that's what allows the flex as the outdrive tilts up and down with the trim. I assume there was another piece of tubing on the inside of the stern that leads up to the gear oil reservoir.
    I can't tell you anything about a Bravo so I don't know if they have the same setup. Mine was only cracked and that's why it only leaked out bit by bit. I remember seeing an oil sheen behind the boat and wondered where the source might be and it took removing the outdrive to get a good clean look to find that little booger.
    KJ
  5. #5
    Join Date
    Apr 2006
    Location
    Posts
    234
    UPDATE -- Pulled boat - Bravo 3 drained oil. Pulled drive from transom/gimbal assembly. Did a 15 psi pressure test - for 24 hours or more. Spun shaft etc - no change in pressure. I'm replacing the drain plug seals for the heck of it.
    Where might I look next for a loss in oil ?
  6. #6
    Join Date
    Apr 2006
    Location
    Posts
    234
    Any input would be appreciated
  7. #7
    Join Date
    Apr 2006
    Location
    Posts
    234
    I found where its leaking ! It's leaking near the shaft seal, where the drive goes into gimbal bearing etc. - it left drive oil in the bellows.
    Is this a big project ? What is entailed in the repair ?
  8. #8
    Driveshaft seal carrier is what I'm replacing now also. There's a few videos on youtube and i suggest you get the seal and carrier installed together already. I had a leak all summer (brand new rebuilt b3) and whoever pressed the seal into the carrier didn't use the proper seal driver and dented it during the process causing it to leak. You'll need to a special torque wrench to set rolling resistance also. I still need to acquire one, hopefully borrow as they are about $200.
  9. #9
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,829
    Quote Originally Posted by Chrisvr6 View Post
    Don't forget to time the gear set.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  10. #10
    Quote Originally Posted by Docksidemarineservices View Post
    How and why must one time a gear set? First I've heard of this.
  11. #11
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,829
    Get the service manual....If you do not do this you will have shifting problems.
    There is more to changing the seal than just replacing it.
    Chris
    Jersey Shore.
  12. #12
  13. #13
    Thanks for that docksidemarineservices! I think this is what you are telling us about?
  14. #14
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,829
    Yes it is.
    + over - Or - over + .......as long as they are exactly lined up there will be no issues.
    Also get the chart for figuring out the torque wrench setting according to the length of your spanner wrench.
    Chris
    Jersey Shore.
  15. #15
    Join Date
    Apr 2006
    Location
    Posts
    234
    Update:
    Had my mechanic do this repair. Odd scenario. He took the Yoke assembly and gears out. The oil seal was fine.
    The Yoke assembly, where the oil seal fit had a slight groove so he said it should be replaced ( he replaced the whole assembly, yoke, universal, seals ). Also, the yoke/ socket was loose.
    The odd thing and I can't understand it - he said the nut at the yoke end was on backwards - said it had no tension at all. He said someone had 'been in there' and it did not look like OM. I bought drive new and never had any work done on it ?! Only explanation I can think of is that the mercruiser guy I bought it from did some hanky-panky. The drive when installed new looked BRAND new... That was 900 hours ago and 14 years...
    Lastly - he said pressure test, as I stated earlier, had no leakage - but, the vacuum test did. This guy is a certified mercruiser mech - he's excellent ( and $$$ ).
    The job seems simple but I do believe there are torque and certain spec parameters that were beyond me. My wallet hurts, but I know it was done right.
Similar Threads
  1. 2003 350mag bravo III stern drive universal joints
    By 3-legged-dog in forum Mercruiser Sterndrive Forum
    Last Post: 04-27-2016, 07:38 AM
  2. 2003 350 5.7L MAG MPI with Bravo 3 - Drive play
    By abl1111 in forum Mercruiser Sterndrive Forum
    Last Post: 07-30-2015, 11:33 AM
  3. 2003 350 5.7L MAG MPI with Bravo 3 - R/R Impeller
    Last Post: 04-03-2015, 07:00 AM
  4. 2003 - Bravo III
    Last Post: 12-27-2013, 08:33 AM
  5. 2003 Mercruiser 57 MPI with Bravo III
    By mcperrault in forum Mercruiser Sterndrive Archive
    Last Post: 07-09-2006, 10:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
