Click for Honda Manuals, Parts and Model Guides!
Results 1 to 3 of 3
  1. #1
    Default 2003 bf 225 seal problem
    The seal, part # 63718-zy3-000 seal A, between the lower engine covers (lower cowls) and the top of the mid shaft housing has pulled out of place and broke. Does the mid section housing have to be removed to replace this seal? Thought I might be able to replace the seal by just removing the lower cowling but looking at a picture of the seal, it looks like a large "O" ring type of one continuous loop. I was hoping it was have a split in the loop where I could just insert into a grove by wrapping it around. I'd appreciate any thoughts.
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,094
    Default Re: 2003 bf 225 seal problem
    I'm pretty sure that it's a single piece seal and the upper cowling must be removed (or at least loosened up all the way around) to replace it, although I've never had to do that myself. The upper cowling is not difficult to remove/loosen - just a lot of 10 mm bolts. Most of them are the same size EXCEPT those around the housing for the cables and fuel line. Just mark those where they came from.
    Then take the gasket and work it around the lower leg and work it up over the mid shaft housing until you can get it in place. Make sure that the grove it sits in is very clean.
    CHawk 25 DLX
  3. #3
    Chawk, If you mean working the seal around the prop and up the mid shaft, i don't think I can work the seal up around the lower leg, the shaft the outboard swivels on will stop me from coming up and the motor, of course, will stop me from coming down.
Similar Threads
  1. Water Pump shaft seal leaking 5.7, 350 Mag 300HP MPI - 2003
    By abl1111 in forum Mercruiser Sterndrive Forum
    Last Post: 07-14-2015, 05:34 PM
  2. Driveshaft spline seal retainer problem
    By sheriff251 in forum Chrysler Force Outboard Forum
    Last Post: 02-07-2014, 09:12 AM
  3. Volvo Penta 2003 oil seal diagrams
    By kruisn in forum Volvo Penta Diesel
    Last Post: 03-23-2009, 02:59 PM
  4. 50hp Force Driveshaft spline seal retainer problem
    Last Post: 02-26-2009, 05:11 PM
  5. Mercury 200 outboard drive shaft seal problem
    By garym23 in forum Mercury Mariner Outboard Archive
    Last Post: 05-09-2008, 10:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
