Click for Volvo Penta parts and manuals!
Results 1 to 6 of 6
  1. #1
    Default 1998 Volvo 3.0l sea water pump leaking out by shaft...
    As the title say's my 3.0 Volvo's sea water pump is leaking out were the shaft goes into the housing. What do I need to do?
  2. #2
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,646
    Default Re: 1998 Volvo 3.0l sea water pump leaking out by shaft...
    Replace pump.... not usually fixable for that flaw.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  3. #3
    I'm starting the disassembly. I figure since I'm going to replace the seal I should replace the bearing too. Does thet sound like a good idea?
    All I will need is the seal, clip, and bearing, right? Can I order these parts separately?
    I have my bearing puller setup on the shaft. Does this look correct? I am concerned that the brass housing will not withstand the lateral force of the puller.
    Do I need to remove the little clip inside the seal before I push the shaft out?
    I've uploaded some pictures.
ID:	16470Click image for larger version.
  4. #4
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,646
    If the shaft is scored, replacing the seal will be futile.
    Capt Bob
    1972 22ft Bristol
  5. #5
    The bearing seems tight and like new, so I decided to just replace the seal. The shaft seems to be smooth. The seal is visibly worn from the shaft spinning in it over time. Now I just need to find a new seal and do a pressure test to see if this solved the problem.Click image for larger version.
ID:	16473Click image for larger version.
  6. #6
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,698
    Quote Originally Posted by sandkicker View Post
    That is not the opinion he wanted to hear.
    Bob, you are correct. These pumps are crap and when they leak you replace them. His repair will fail.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
Similar Threads
  1. Water Pump shaft seal leaking 5.7, 350 Mag 300HP MPI - 2003
    By abl1111 in forum Mercruiser Sterndrive Forum
    Last Post: 07-14-2015, 06:34 PM
  2. Replies: 19
    Last Post: 06-30-2014, 07:16 PM
  3. Replies: 1
    Last Post: 07-14-2013, 09:48 AM
  4. Prop shaft leaking water into the boat
    By rossbruno in forum Marine Transmissions and Reverse Gears
    Last Post: 09-28-2012, 07:30 PM
  5. Water leaking around shift shaft
    By jshane37 in forum Mercruiser Sterndrive Archive
    Last Post: 07-03-2007, 08:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
