overheating recommendation 5.7 alpha 1
outobie
hi all:
I come once again to the well of knowledge here.
I'm looking for some advice on diagnosing my symptoms and confirmation / suggestions on my course of action.
background.
27' tiara 1987. repowered in 2001 with Mercruiser 5.7 alpha 1 gen 2. with 600 hours and 16 years on motors.
manifolds and entire engines are original 2001 wet joint manifolds in .
I purchased the boat this past april and put 100 hours this season and the motors ran great.
my original plan was to replace the manifolds etc this fall but on my last outing my starboard engine ran hot enough to trigger the overheating alarm when I was running WOT. ( I always run WOT for about 5 minutes every cruise to keep them in shape).
after cooling down the starboard motor ran normal temp and my normal cruise speed but began getting warm if I pushed it.
when the engine overheated I noted the following. both manifolds, elbows, thermostat housing, etc were equally hot, no one spot hotter than another.
the outdrive was fully serviced in July with new OEM water pump, hoses and bellows, oil etc. including new OEM thermostate
after the overheat I noticed a lot of steam coming from the exhaust of the starboard motor.
I've decided to end my season and do the manifolds, etc now.
my question is this. what is the most likely cause of the overheating?
I expect my problem is upstream of the manifolds because the temperatures were equal everywhere. where would you look? and is my thinking sound?
my plan is to replace all manifolds, all hoses, elbows and the water circulating pump and thermostate...and to flush the power steering cooler.
what else should I consider?
thanks for your help
I shut down
Raw water cooled manifolds and elbows have never been changed since new in 2001 (yes I know, way beyond due) and were already part of the plan to change before my recent overheating incident.
the overheating problem developed suddenly. Prior to and all season, temp remained extremely consistent even under heavy load. Now temp is normal at idle and cruise speed of 3000 RPMs but will creep up in heavy seas or when pushed harder
changing the water circulating pump is currently part of the plan
since motors are raw water cooled there is no raw water pump other than what's in the outdrive
Assuming the work done in July was complete, I'd bet on the exhaust elbows being at end of life....
no need to change the manifolds unless they are thin or distorted.....I doubt the circulating pump is a contributor unless it is noisy....
New Manifolds are ordered with the elbows.
I still don't know where else to look. What would cause the whole motor to overheat? If an elbow had failed or manifold water passage got clogged I would expect a localized hotspot rather than equal temps
is this thinking wrong?
What about the flapper valve?
dont these motors have a flapper valve in them, in the exhaust "Y"?
if that failed could it cause overheating? How can I check for this ?
also what about the power steering cooler? Is this something that needs to be replaced or serviced on some timeframe?
1).... poor flow in the manifolds/elbows will result in engine overheat. Lack of a hot spot not definitive.
2)....I went 9 seasons on my FWC engine w/dry joints before doing elbows that were flushed regularly with fresh water
and THAT was considered... "pushing it"
3) Steaming... poor flow of cooling water or a blown head gasket
4) " 5 min @ WOT to... keep them in shape". IMHO that's about 4 min and 45 sec longer than justified. Cruising @ 80% or less of MAX WOT RPM all you need to "keep your engine in shape". After all, you don't run your car or truck at redline in a lower gear for 5 min to keep you vehicle " in shape"????. But, dude, it's your boat!!!! I've talked directly with factory marine engine manufacturers on the whole RPM issue and they and an independent engineer who did consumer engine life tests, agree.... engine life at WOT is measured in tens ( 30 to 50) of hours of life. Given that a new engine can easily cost $10,000 (and above!!!) installed that's $200/hr operation. FWIW, I run my boat WOT 3 times a season ( @ launch, mid season and pre haulout) and then only for 10 to 15 secs, and that's just to check engine state of tune and cooling system health. Been doing this every season since I bought my first boat in 1964. I've only ever replaced 2 engines, one of which hung a valve ( a very very used, new to me boat) and another that was a 1969 raw cooled ( sea water) engine in 2007, the season after I bought it.
Maybe I'll reconsider the WOT strategy��
Its actually a bit too fast at WOT for my comfort.
i thought i was doing good for the motors
what is considered normal cruising speed for these motors?
boat will plane at 18 knots 2600 rpm
i normally cruise comefortably at 22 to 24 knots at around 3000 rpm (depending on seas)
WOT is 4600 rpm at 38 knots
idle is 4 knots at 650 rpm
all speeds are gps speeds
the speedo gauge driven off a water pickup in one of the outdrives reads about 3 knots lower
again, overheats start with a bad/worn/damaged raw water impeller. Start there first
Before you reinstall the lower ,put muffs on and see if there is any leakage, water leaking out = air getting in
ASSUMING (!) that 4600 RPM is within the specified MAX WOT RPM for that engine ( check decal on flame arrestor) then 80% of that RPM , i.e., 3680 for good life, 75% (3450) for better life. Speed is whatever that hull will do with the load... GPS reads speed over ground, speedo pickup is speed thru water with somewhat indifferent accuracy and varies with current direction relative to boat.
Correct WOT range according to decals and the manual is between 4400 to 4800
so I'm dead center of that range
is my normal cruise speed of 3000 rpm too slow? Ie is there a sweet spot that's best for fuel economy and longevity?
as I check for leaks on the outdrive water pump, where should I be looking?
is there a documented procedure someone can point me to?
being a GEN II you may se a trickle from the slinger seal on the driveshaft,and maybe a bit from the water outlet tube but nowhere else
Re: cruise @ 3000.... no that's fine! engine life continues to improve as cruise RPM drop to 60%. I run about the same RPM on my boat and find the 3000 rpm is a nice speed. My rule of thumb is boat on plane, nose drops and plus 50 rpm is minimum cruise and per some folks here that is about the most economical.
Not to be stupid but
how do you check those areas which are inside the drive? I was under the impression that the motor needed to be running and on muffs to check fire keaks
There are none ,your checking the lower units water pump by itself before you install the lower unit.
from the top of the SS pump body is a guide sleeve for the copper tube. From there are machined holes in the casing directing the flow thru the drive, thru the gimbal housing, thru the hose to the fitting inside the boat and then to the engine. In some cases that hose can collapse internally and restrict the water flow.
In July I my mecury dealer serviced both of my drives.
new bellows new water pump new seals new hose with OEM mercruiser parts.
ill pull the drives and check again but I'd really hope the service life of these parts is longer than 2 months. The old hose and bellows lasted 16 years and were still performing well when replaced
i was reading through the shop manual and it said you can test for reduced flow from the outdrive by disconnecting the intake hose from the outdrive and measuring volume into a bucket...Idle the motor at 1000 RPMs for 15 seconds and you should get 4 quarts of water
Re:.... 2 month service life.... 20 to 30 seconds running dry is full service life. Some random (short) time bumped into a sand/gravel/mud bank also "full service life".
No argument on that
doesnt apply here though
boat is wetslipped... outdrives haven't been out of water since installed
boat is run in deep water shallowest draft is my slip which is 9 foot
temps are are cool and steady at idle up to cruise speed... only starts getting warm when run hard.
parts are all ordered, should be here next Friday so next Saturday I'll dig in.
gonna start with manifolds, elbows, circulating pump and all new hoses and tubes and thermostats on the inside.
Will also inspect and clean the power steering cooler and do a compression test.
then run it to see what happens.
ill pull the drives when I pull the boat for winter... next month if the above effort solves my overheating issue or sooner if not
There was some that I got after with a pressure washer and scraper
then we painted it with an antifowling paint for outdrives
Yes I assumed that's what you meant
when we replaced the water pump in July I took the pressure washer to all the internal passages I could get to and a scrapper or thin screwdriver for everything else. It has some growth but not terrible
started digging into the exhaust system today. so far I removed the port elbow and manifold and several hoses and drained the block.
no evidence of water intrusion in the manifold all gasket and sealilng surfaces thick and dry. did find some internal rust flaking causing partial obstruction of the elbow...maybe 15% obstruction...also discovered that half of the flapper valve on the port side of the Y pipe is missing.
I ran out of time to look for the missing chunk but I suspect that will be a contributing factor in my overheating condition. if I can't find the missing piece, what are my options? will I be afforded access to the bottom of the Y pipe with the outdrive removed? or is it more likely to be lodged inside the outdrive? is there a common location that these chunks usually end up?
thanks
John
Quick question on doing this job in the water.
I hadnt considered waterline. When I removed the exhaust manifold, elbow etc, there was water just about up to the top of the Y pipe. As the boat rocked a little some water sloshed over the top and into the bilge. Had the top of my Y pipe been 3 inches lower I could have sunk my boat when removing the system.
i reinstalled the tubes on the y pipe to give me a few more inches.
now I'm thinking about the intake hose from the fitting on gimbal housing to the power steering cooler. This fitting is below the water line. Will removing the hose from this fitting allow water to rush into the boat?
