bansheejoel
So I just bought a fishing boat from a elderly man who was the original owner and only used the boat a dozen times, literally brand new. The engine is a 98' 75hp elpto 2 stroke. It ran good except it sneezed when starting and idled like crap. I did the normal stuff, fresh gas, new plugs, rebuilt all the carbs, rebuilt the fuel pump, adjusted the air screws etc. I couldn't get it to run any better so I bought a oem mercury manual and did the "link and sync". In order to get the roller and throttle cam white lines to match up took quite a bit of adjusting the idle stop and throttle cable. All seemed good until the last step, timing. The idle timing was in the ballpark where I needed it 5°btdc (obviously will have to adjust to get the idle I want). The issue came when I times the maximum timing, factory setting where the paint is on the adjuster read 27°. Should be 20° at cranking speed so I adjusted the adjuster. In order to get the maximum timing set I almost bottomed out the adjustment screw. Something feels off, I am nervous something isn't quite right. Any ideas? Thanks!
