Results 1 to 8 of 8
  1. #1
    Join Date
    Sep 2017
    Location
    Alvin
    Posts
    7
    Default 1997 150 johnson fast strike
    1997 johnson 150 fast strike run great for 20 30 miniutes then after sitting 30 miniutes it starts but will not go more than 2200 rpm every so often it will rev up for a second sometimes 3 to 5 seconds it has completely shut down a time or 2
  2. #2
    Join Date
    Apr 2010
    Posts
    4,134
    Default Re: 1997 150 johnson fast strike
    What happens if you hit the choke when this acts up ??
  3. #3
    Join Date
    Sep 2017
    Location
    Alvin
    Posts
    7
    Quote Originally Posted by Boobie View Post
    The motor bogged down , almost died then stayed about 2200 rpm
  4. #4
    Join Date
    Apr 2010
    Posts
    4,134
    Then try doing a cylinder drop test on it when it's acting up to find what cylinders are acting up.
  5. #5
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,901
    Disconnect the heat sensors on head and test. as it may be going into slow...
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  6. #6
    Join Date
    Sep 2017
    Location
    Alvin
    Posts
    7
    Heat sensor checks out good
    seems to run fine when the shift switch is not installed it is plugged in and grounded just not stabbed into position
    while in position i have no spark left side (harbor) runs good when leaving the dock then it seems to go into limp mode While on the water I removed the shift switch seems to be running good.
  7. #7
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,901
    Shift cable out of adjustment or shift rod binding triggering shift switch
  8. #8
    Join Date
    Sep 2017
    Location
    Alvin
    Posts
    7
    Thanks for all the advice
Similar Threads
  1. 1997 Johnson 115 Fast Strike - hot indicator
    By gjordon in forum Johnson Evinrude Outboard Forum
    Last Post: 08-11-2017, 09:58 PM
  2. 1997 Johnson fast strike 150hp surging at idle
    By Mharms in forum Johnson Evinrude Outboard Forum
    Last Post: 05-30-2017, 02:00 AM
  3. 1997 Johnson Fast Strike 150 shutting off under a load
    By Bobby Smith in forum Johnson Evinrude Outboard Forum
    Last Post: 06-22-2015, 10:07 AM
  4. 1997 Johnson 150Hp Fast strike Ficht
    By Chuck Kiser in forum Identifying Model / Year / Horsepower
    Last Post: 05-17-2014, 10:28 AM
  5. Johnson 1997 175 hp Fast Strike (loses power and cuts off under any kind of load)
    By DanBassMan in forum Johnson Evinrude Outboard Forum
    Last Post: 05-07-2011, 01:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
