Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 8 of 8
  1. #1
    Default Tohatsu TLDI md50a 2001 / Fuel dripping from air intake into tps sensor
    Hi
    I have had quite a struggle with my engine. It behaves really strange from time to time. Last season a had these issues:
    http://www.marineengine.com/boat-for...=tldi+blinking
    I thought I solved the problem by adjusting the throttle cable against the stop and reset the tps sensor. This season the problem appeared again and reset hasn't worked. Last time we were on the water it was making different strange things. Lights blinking, warning sounds, rpm increasing suddenly but no change in speed of the boat (like propel was slipping in the water or rubber in the propel is worn), etc.
    I checked the cabeling and found it alright.
    Therefore I have purchased a new tps sensor and installed it today. Sofar I don't know if it is going to finally solve my problems but I noticed something. When I pump the ball on the fuel line it starts dripping fuel directly into the tps sensor from the air intake right above.
    Is that normal?
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,090
    Default Re: Tohatsu TLDI md50a 2001 / Fuel dripping from air intake into tps sensor
    No. Something is very wrong. What do the diags say?
    Paul
    Buffalo NY USA
  3. #3
    It still says it's a problem with the tps sensor. Maybe the old tps sensor failed because fuel was dripping into it.
    I haven't been on the water with the new sensor. Just want to prevent that it's ruined before I get so far.
  4. #4
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,090
    A DFI motor should never drip fuel; Something is quite wrong.
    Paul
    Buffalo NY USA
  5. #5
    Quote Originally Posted by pvanv View Post
    It's a TLDI. Guess it's the same. What could cause this?
  6. #6
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,090
    Cylinder compression could possibly overpressurize the VST when the FFP is off, but aside from that, there should not be any fuel drips. Look for a bad hose, gasket, etc. If you can see drips, you should be able to find the source of the leak.
    Paul
    Buffalo NY USA
  7. #7
    Weather is really bad for the moment with storm and heavy rain so I haven't done anything yet. Anyway I have spent some time reading my Seloc repair manual. Especially about the fuel system. I now understand that the VST is working as a reservoir for the FFP and it has a built in float like a carburetor. If this needle isn't tight then where is the fuel lead to? If it's lead anywhere except for being forced through the FFP pump.
    I'm not sure what you mean about the compression in the cylinder? When I pump the ball the engine is off and no compression has yet been built up.
  8. #8
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,090
    The VST is a reservoir to allow the fuel vapors to leave. The FFP is the high pressure pump, and that draws from the VST. The VST does work like a carb float. When full, no fuel should go anywhere. The FFP will pressurize the high pressure fuel rail based on the pressure regulator.
    Paul
    Buffalo NY USA
Similar Threads
  1. Tohatsu md50a 3 lights blinking
    By jakob j in forum Nissan Tohatsu Outboard Forum
    Last Post: 08-15-2016, 08:58 AM
  2. Replies: 4
    Last Post: 06-28-2011, 05:54 PM
  3. 2001 Tohatsu 9.9 hp Fuel Pump Issue?
    By gdurhamu2 in forum Nissan Tohatsu Outboard Forum
    Last Post: 02-12-2011, 08:20 AM
  4. Tohatsu M40D 3C8 parts compatability with MD50A
    By sobie2 in forum Nissan Tohatsu Outboard Forum
    Last Post: 10-13-2009, 09:35 PM
  5. Tohatsu TLDI vs four stroke fuel comsuption
    By player in forum Nissan Tohatsu Outboard Forum
    Last Post: 09-10-2009, 12:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
