Results 1 to 18 of 18
  1. #1
    Join Date
    Sep 2017
    Location
    Carrying Place, ON, Canada
    Posts
    5
    Question New here and just figuring things out.
    My mercruiser MCM 190/488 has a leaking engine oil cooler. It is leaking coolant out into the bilge. For some reason my Seloc manual has nothing in it about this cooler. Might there be any forums or write ups on this repair.
    Thanks,
    Jamie.
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,181
    Default Re: New here and just figuring things out.
    thats because its a SELOC. The heat exchanger is either 3 or 4 inch .there are 2 drain plugs in the aft end. rearmost is raw water, forward is the A/F side.
  3. #3
    Join Date
    Sep 2017
    Location
    Posts
    5
    Sorry, it is not the heat exchanger that has a problem. It is the oil cooler that is located below the intake manifold and above the oil filter that leaks coolant.
    Jamie
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,158
    The only "oil cooler" that should be there is the power steering fluid cooler.....and that doesn't have "coolant" in it, only raw water and the PS Fluid...
    If the PS cooler is leaking, and its original, probably best to replace it....less desirable option would be to remove it and take it to a radiator shop for testing/repair.
  5. #5
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,730
    Just replace it if it is leaking. Do not take a chance on repairing it they are a preventive maintenance item and should be replaced at regular intervals.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  6. #6
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,181
    Quote Originally Posted by makomark View Post
    Find regular A/F leaking from there means the heat exchanger is leaking A/F into the raw water side of the cooling system
  7. #7
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,181
    found your oil cooler, its on page 7A-6 of manual 8 the site I use for pics is down ,
    You may have to use a regular transmission cooler (not a power steering cooler) for the engine oil and remove your item and screw the oil filter direct to the block
  8. #8
    Join Date
    Sep 2017
    Location
    Posts
    5
    Thank you. The leak is around the plate that secures the bottom of the cooler to the intake manifold. I was told there is a long O-ring that is problematic. Of course this part is no longer available they told me. Either have a long O-ring made or use high temp gasket maker, apparently. Just was hoping someone had tackled this job and had advice.
    will try your suggestion with the manual. Does one have to pay to see it?
    Jamie
  9. #9
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,181
    Never had to change one but it might be the same one used on Ford oil filters.The same part number for the oil filter gasket and the housing.
  10. #10
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,181
  11. #11
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,181
    unless you mean #11
  12. #12
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,181
    To do it correctly remove the plate and clean the surfaces.Apply a consistant narrow bead in the cover about 3/16 above the edge of the cover and walk away untill the next day. LET IT CURE
    Install and tighten cover
  13. #13
    Join Date
    Sep 2017
    Location
    Posts
    5
    Hi Bt Doctur
    The diagram looks exactly like the one in question. Will take it apart with a bit more confidence now.
    Sure glad the coolant leaked out into the bilge rather than into the engine oil.
    It would seem there are O-rings where the oil passes through the plate. Will find out I guess.
    Will follow your instructions
    And thanks for taking the trouble to figure this thing out.
    I have heard that these 488 model engines were less than successful. It seems the Al block had no sleeves in the cylinder bores. The local marine guy told me to keep the revs below 4000 rpm and we won't have any trouble. ??
    Hope he is right.
    Big thanks,
    Jamie
  14. #14
    Join Date
    Sep 2017
    Location
    Posts
    5
    Yes, the "no longer available" is number 11 in the diagram
  15. #15
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,181
  16. #16
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,730
    You can always get bulk o-ring material and just use superglue to join the ends. Just make sure it is the nitrile material. That just looks like a manifold cooler to me. Go to boatinfo library and find your engine.
  17. #17
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,730
    Looking at the flow chart it is warm coolant flowing through the intake jacket to preheat the fuel going into the cylinders.
  18. #18
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,898
    Yes they have sleeves and sold several to dirt track racers...balanced,flowed,custom cam,sheet metal intake,1050cfm holley,8500rpm= lite weight powerhouse of 500+HP!!!!!
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
Similar Threads
  1. 1999 J90PLEEB 90HP Need Help Figuring this out.
    By IcemanVexilarking in forum Johnson Evinrude Outboard Forum
    Last Post: 07-03-2017, 03:03 PM
  2. 1999 J90PLEEB 90HP Need Help Figuring this out.
    Last Post: 07-03-2017, 03:02 PM
  3. figuring out what year
    By Charger25 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-24-2012, 09:01 AM
  4. Need Help Figuring out fuel lines
    By cali in forum Mercury Mariner Outboard Archive
    Last Post: 08-16-2006, 11:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
