Results 1 to 5 of 5
  1. Default 1999 3.0 Volvo sounds like an old-school hit & miss engine
    I just had all fluids changed and the engine gone through to make sure it was in good shape. Today, I was riding around and I started hearing an air noise from the engine that sounded like and old-school hit & miss engine. The engine also sounded like it may have valve chatter.
    Any ideas with whats up?
    P.S., the Volvo 3L blocks are the same as Merc, right?
    Jun 2008
    Island Heights, NJ,
    2,644
    Default Re: 1999 3.0 Volvo sounds like an old-school hit & miss engine
    Check compression, may have hung/burned intake valve... or blown exhaust manifold to block gasket.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  3. Default Re: 1999 3.0 Volvo sounds like an old-school hit & miss engine
    I plugged off the little coolant hose that runs to the riser and hooked a pressure tester up to the coolant hose going into the manifold. All the air I am pumping in is exiting out of the exhaust. Any ideas? What next?
    I also pressure tested the block with the manifold and rider out of the loop. It held 20 psi overnight, so no block issues.
  4. Default Re: 1999 3.0 Volvo sounds like an old-school hit & miss engine
    I am removing the manifold. I have already removed the riser. The exhaust pipe is directly in front of the back bolt for the manifold. The exhaust pipe runs under the engine and, I assume, connects to the lower unit housing. I cannot see the end it is so far below the engine, and therefore, do not see how I can remove it. Am I missing something here? Surely I do not have to remove the engine to pull the manifold.
    Checkout the pic. Click image for larger version.
  5. Default Re: 1999 3.0 Volvo sounds like an old-school hit & miss engine
    So I double nutted it and broke the stud loose, but now even the stud is hitting the exhaust pipe. How long are these studs? Am I going to have to remove the entire head to remove the manifold?
  1. 1999 Yamaha 115 two stroke- Bad stutter, sounds like rev limited,
    By big_builder in forum Yamaha Outboard Forum
    Last Post: 04-27-2015, 09:31 PM
  2. Volvo Penta KAD 44 B, C Banging Sounds!!
    By Philippe Pageau-Goyette in forum Volvo Penta Diesel
    Last Post: 04-12-2014, 01:48 AM
  3. Volvo penta 43 sounds loud in Glastron
    By schadow in forum Volvo Penta Gas Archive
    Last Post: 01-18-2008, 12:01 AM
  4. Outboard engine repair school
    By kdp in forum Archive 2003-2007
    Last Post: 01-03-2007, 09:07 PM
  5. 50 liter volvo penta engine miss
    By stump in forum Volvo Penta Gas Archive
    Last Post: 08-21-2006, 05:49 PM
