Hi Guys
I have a 2000 4.3 gl carbed motor that falls on its face between 2500 -3000 rpm and often stalls, however is does not backfire thru the carb and restarts quickly.
There is no fluctuation on the tach. I have run this motor directly off of a 5 gal gas can with new fuel line. Same issue.
The secondary metering plate on the Holley 4160 was plugged so I rebuilt the carb. Same problem. I have 7 psi fuel pressure at idle but it drops to zero when it acts up.
I have run the fuel pump with a jumper wire between 30 and 87 at the relay cavity and don't see a voltage drop on either the power or ground side at idle. The fuel pump is new. I would expect to see more than o psi at 2500+ at my guage which is teed in between the electric fuel pump and the carb.
Even after returning to idle it takes some time to recover to 7 psi.
I suppose I should monitor the ignition with a timing light flash but can't get over the fuel pressure drop. I also may run the power and ground leads to the fuel pump directly to the battery.
Any help would be greatly appreciated.
Thanks in advance
Jon Allen
Thanks in advance
Jon Allen
