Click for Volvo Penta manuals!
Results 1 to 2 of 2
  1. #1
    Default Volvo D12 675 overheating alarm at low speed
    Hi, have a overheating problem on the princess 50 2006 on Volvo D12 675 port side engine only (stb side is Ok). When I'm in navigation and the engines running abut 1100rpm or more(also on maximum), both engines are on 86-87 degress, then If I slow down under 1000rpm, left engine is going very fast to overheating alarm??? Impeler is new, termostat also, heatexchanger is cleaned with "barnacle buster", new temp senzore..., the engine has only 400 working hours...does anyone had a similar problem??
    Thanks, and sory for my bad language
  2. #2
    Join Date
    Jun 2008
    Location
    Posts
    564
    Default Re: Volvo D12 675 overheating alarm at low speed
    Sounds very strange that it overheats only at low rpms. Have you checked that it is really overheating using an infrared heat gun etc? If it is really overheating I would first check for air leaks between the raw water pump and the water pickup (through hull). At 400 hrs you shouldn't have issues with the water pump itself but maybe an air leak in the strainer or piping? An small air leak may cause low water flow when the impeller is spinning slowly but let enough water through when it is spinning faster. There are probably seals inside the pump that might cause this type of effect also but I would expect to see small drips of water from the relief hole in the pump if these were leaking. Have you checked to see that the strainer is staying full when you are at the overheat rpms?
Similar Threads
  1. Overheating at idle speed
    By Gfechtenburg in forum Mercruiser Sterndrive Forum
    Last Post: 06-09-2016, 12:12 AM
  2. Volvo tamp41p-a alarm does not sound when alarm test pressed
    By SteveScott in forum Volvo Penta Diesel
    Last Post: 06-23-2012, 01:42 PM
  3. 225 efi high speed overheating
    By fins6969 in forum Mercury Mariner Outboard Archive
    Last Post: 03-14-2009, 09:21 PM
  4. Over speed alarm
    By 18hb in forum Mercury Mariner Outboard Archive
    Last Post: 06-20-2008, 09:53 AM
  5. 30L 1992 Overheating at low speed help
    By onlyfinol in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-16-2007, 09:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
