Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 6 of 6
  1. #1
    Default Again steering issues 91 Bayliner 120 force engine
    As I have read many other people with this issue, I have yet to find how to replace these bushings. The steering wheel spins fine when cable is detached, that shows me the king pin bushings are at fault. I purchased the bushings, but not before greasing the hell out of it and trying to work the motor side to side with no relief but sore arms! I have even tried using a grease gun filled with mineral spirits to hopefully disolve the old grease but that didn't help either, so anyone here replaced these bushings and what was the procedure? I am a mechanic, but not with boats but with cranes, and I have run into bushing problems on those also. Thanks to anyone! Not looking forward to this job.
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,567
    Default Re: Again steering issues 91 Bayliner 120 force engine
    The mineral spirits and a propane torch and marine grease is the ticket.
    I NEVER use anti-seize on anything marine.
    The bushings are REAL hard to change.
    What I have done.
    At the top and bottom where the bushing would be, I installed grease fittings.
    The fittings in there now are pressed in and pop out easily.
    So don't use a grease gun there unless it goes in easily.
    I heat the top and bottom and add grease and then turn and push the motor back and forth.
    Depending on where you live the difficulty depends on the water you boat in.
    Salt water? Amost impossible.
    Fresh? Just real hard.
    You pretty much need to take the motor apart to get to the bushings.
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
    88 Bayliner with 2002 225 HP Mercury
    Buy American made Cars and Trucks!!!Towing insurance,get it.
    In Scenic Beautiful Sebastian by the sea Florida
  3. #3
    Quote Originally Posted by Jerryjerry05 View Post
    What I have done.
    Thanks Jerry I'll give it a go. I got the boat for free and it runs! The floor and steering are all I see that is major. Came from Newport News VA Im assuming salt water.
  4. #4
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,567
    Let me know how it comes out??
    The bushings are plastic and will melt and seize if you get them too hot.
  5. #5
    Join Date
    Mar 2008
    Location
    Bruford SC , U.S.A.
    Posts
    326
    Jerry, Why no anti-seize...???
  6. #6
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,567
    Anti sieze turns to PERMA FREEZE when around salt water and even to some extent when used in fresh water.
Similar Threads
  1. how to find which distributor is in my 1989 17ft bayliner 2.3 ford force engine
    By steve new in forum OMC Sterndrive and Inboard Forum
    Last Post: 03-18-2015, 09:31 PM
  2. 86 Bayliner carb issues??
    By uscgret in forum Volvo Penta Gas Engine Forum
    Last Post: 08-10-2010, 02:20 AM
  3. 1998 Force Engine Steering is frozen
    By josatdy in forum Chrysler Force Outboard Archive
    Last Post: 07-18-2007, 07:51 PM
  4. 05 bayliner power steering
    By doug_k in forum Mercruiser Sterndrive Archive
    Last Post: 03-03-2007, 07:27 PM
  5. VERY HARD STEERING ON A 88 BAYLINER CAPRI
    By Bob Hildebrand in forum Outboard motors archive 2000-2004
    Last Post: 06-12-2002, 10:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
