Results 1 to 13 of 13
  1. #1
    Default Lose spark above 4000rpm
    I have a 1988 Cris craft with a 4.3L & an omc drive. Boat runs great from idle to 3000 rpm then starts popping and studering . When you put a timing light on it you can watch the spark go away. Seems like the slower you rev it, the longer it takes to lose spark but never rev's above 4000. I used to run all day at 4600 rpms. What am I missing ?
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,186
    Default Re: Lose spark above 4000rpm
    Obviously something in the ign system coil failure, plug wire failure, rotor/cap failure, sparkplugs
  3. #3
    All brand new, just switched to electronic ignition
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,163
    I'd suggest going back over your 'new' work.....If it was ok before the 'mod' then the issue is highly likely coupled to the 'mod'....
  5. #5
    The issue was the reason for the mods. Unfortunately I have double and triple checked everything. Water tested 4 times same result, seems to get worse the longer you run it, "better" when engine is cooler. Did compression test & all 6 were within 3# of each other.
  6. #6
    We have changed both feul filters both were clean and free of water. Someone mentioned shift assist? Not sure what that would have to do with it?
  7. #7
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,163
    The ESA can be the issue, especially if the new ignition system has a high current coil.....
  8. #8
    Quote Originally Posted by makomark View Post
    It does but the issue was there before the mod. Could it be shift cable adjustment ?
  9. #9
    Thank you for trying .
  10. #10
    Quote Originally Posted by Nitrofan16 View Post
    Sounds like your spark isn't hot enough.built in condenser ?
  11. #11
    Thank you
  12. #12
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,790
    If problem same as before, then likely something you didn't change... Are you using the same coil?
    re: " Used to run all day at 4600 rpms(sic) ".... All day at 4600 rpm is " Put a $100.00 bill every hour in the "buy a new engine jar" boating". You should limit continuous operation to 80% of MAX WOT, i.e., 3680 RPM for reasonable life.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  13. #13
    Ended up figuring out that I started with a bad condenser and ended up with a bad rotor (brand new) 3 days of trouble shooting to find the rotor problem, crazy. It's fixed now and runs great. When I said 4600rpms all day I meant in short bursts. In the end I appreciate everyone's input and time THANK YOU ALL I'm now hooked on this forum !
Similar Threads
  1. 1997 225HP Mercury outboard dies off after 10 min # 4000RPM
    By Gary Brown in forum Mercury Mariner Outboard Forum
    Last Post: 09-03-2017, 12:34 AM
  2. 1994 Yamaha 225hp TXRS dies out at 4000rpm
    By rabrador in forum Yamaha Outboard Forum
    Last Post: 06-24-2010, 09:11 PM
  3. DF90 Misfire under high load 4000rpm
    By rbatts in forum Suzuki Outboard Archive
    Last Post: 07-19-2008, 10:09 AM
  4. Loss of power at 4000RPM Petronix Ignition
    By fire388 in forum Volvo Penta Gas Archive
    Last Post: 07-06-2008, 05:02 PM
  5. 60hp mariner overheats if over 4000rpm
    By redfish2snook in forum Mercury Mariner Outboard Archive
    Last Post: 04-25-2007, 10:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
