Click for Volvo Penta parts and manuals!
Results 1 to 7 of 7
  1. #1
    Default New old Volvo owner , AQ 170 vacume advance.
    Yep just bought a can of worms no not bait....my new old boat 73 bayliner has a AQ170 there is history of someone who did not know what they were dooing took out the distributor.......before I get to re timing this , I noticed it has a vacume advance - i thought boat engines had mechanical advance , possible the distributor came out of a volvo B30? Car.
    Thanks .......
    oh in Sacramento ca
  2. #2
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,646
    Default Re: New old Volvo owner , AQ 170 vacume advance.
    No vacuum advance on marine disti's.... which gets us to.... non marine disti's not allowed on boat engines.... USCG and insurance company will react "badly" when/if they become aware of it. and, no, you can't upgrade/convert an auto disti to a marine one. Marine one's need to be certified and tagged as such.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,259
    The non-marine-approved distributor with vacuum advance is still a mechanically advancing system. The vacuum advance simply adds additional ignition advance during high manifold pressure (aka coast time)!
    The marine engine never sees coast time, so vacuum advance is not necessary.
    As noted, the automotive ignition distributor does not meet the "ignition source protection" requirements........ AND the ignition advance curve is incorrect for marine use!
    I would find and install the correct unit and set the timing as per OEM specs!
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  4. #4
    Thanks havent had a moment to look for a correct distributor - working on the house and getting closer to being done for this years work .
  5. #5
    Still no time to work on boat but for everyones edification it apears that Volvo did in fact use vacume advance on some aq170 and 165 engines - not good practice by todays standards but reasuring that the engine in mine might be stock and not from a car . Pics are from Volvo AQ manual .
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	16475   Click image for larger version.
  6. #6
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,646
    Must be for the California surfing market ;-)
    Capt Bob
    1972 22ft Bristol
  7. #7
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,259
    Quote Originally Posted by sandkicker View Post
    Very possibly!
    I am surprised to see that! Even with the vacuum diaphragm advancing unit, there is no coast time (no periods of high manifold pressure) on this engine that would allow a vacuum diaphragm advance system to be of any benefit.
    I would make sure that the "Mechanical" advance is working properly, and is giving your Engine the correct OEM ignition advance curve.
    See the OEM curve specs.
    Portland, Oregon
Similar Threads
  1. Maximum Spark Advance vs. Full Throttle Advance
    By Matt Butzer in forum Mercury Mariner Outboard Forum
    Last Post: 11-20-2014, 01:17 PM
  2. new owner 1990 Carver with Volvo Penta outdrive
    By wesleyj in forum Volvo Penta Gas Engine Forum
    Last Post: 01-21-2011, 05:25 PM
  3. Vacume advance for a 188 grey
    By wndowhunt in forum Gray Marine Gas Engine Forum
    Last Post: 06-06-2009, 05:06 PM
  4. 77 volvo 302 advance
    By danial dickinson in forum Volvo Penta Gas Archive
    Last Post: 08-07-2008, 12:38 PM
  5. New owner Volvo AQ171A Question
    By kurt_g in forum Volvo Penta Gas Archive
    Last Post: 04-20-2007, 12:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
