Click for Honda Manuals, Parts and Model Guides!
Results 1 to 3 of 3
  1. #1
    Question 2002 BF225. What size fuel pick up tube to feed two engines.
    Ok so I'm having to chase a problem and I have the chance to change my fuel pick up tube. The current tube is 5/16" Stainless tubing. Is this adequate? I installed it out of necessity at the time but I have the chance to correct it if it is to small. What size does a pair of these engines call for. The tube will feed both engines.
    A pair of 2002 Honda BF225s
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    3,813
    Default Re: 2002 BF225. What size fuel pick up tube to feed two engines.
    I honestly don't know. But it seems the bigger the better. Once fuel gets to the VST the volume of fuel is controlled by the VST and HP pump.
    CHawk 25 DLX
  3. #3
    Quote Originally Posted by chawk_man View Post
    Yeah you can find specs on the HP pump but good luck finding anything on the LP pump. The volume that the LP pump moves would dictate the size pick up needed but I can't find any info on that.
    I just sized up generic (for boats) plastic fuel pick up tubes and made one out of stainless that size. I have not called honda yet so maybe that should become one of the first things I do . LOL.
Similar Threads
  1. Replacing E115eleua fuel pick up tube
    By Georgiaboy67 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-27-2017, 01:02 PM
  2. What is that gold colored gunk in my gas tank feed tube?
    By Bob Parsons in forum Identifying Model / Year / Horsepower
    Last Post: 10-15-2016, 08:17 PM
  3. How to Remove fuel pick up tube from tank?
    By GoldToyBox in forum Boat Fuel Systems (separate from engine)
    Last Post: 03-08-2015, 10:17 PM
  4. kinked water pick-up tube
    By rictec343 in forum Johnson Evinrude Outboard Forum
    Last Post: 12-24-2014, 10:03 AM
  5. question about 9.5 water pick up tube
    By jd81 in forum Johnson Evinrude Outboard Forum
    Last Post: 03-05-2012, 12:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
