Click for Volvo Penta parts and manuals!
Results 1 to 3 of 3
  1. #1
    Default Question about DP-C1 drive
    About 7 years ago I was able to replace my PDS bearing, U joints and shift shaft seal etc. with the info I obtained from this forum and my Seloc book. Everything went almost exactly as it should have with the exception of the rolling torque value setting. Although it hasn't caused a problem in 400 hrs., now that it's time (or past time) to do it all again I want to do it right this time. I remember taking a torque reading before taking the double bearing box apart so I would have a reference. Can't remember what the reading was but it was within specs. but on the low side. I tried to increase the rolling torque value slightly when I put it back together but it would not change no matter how much I tightened the torx/allen (?) screw. Since it was still within specs. I put it back together and have had no problems. Question - if the same thing happens this time should I replace the crush sleeve even if the RTV is within specs. and if so can it be done without a press ?
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,253
    Default Re: Question about DP-C1 drive
    Quote Originally Posted by tarheeltom View Post
    That would be bearing crosses and eccentric piston seal.
    OK..... the DP-C1 suggests V-6 or V-8 power.
    With this power, and with now an additional 400 hours on the transmission, I would be looking at and/or replacing the 30207 and 31307 bearings.
    If these are replaced, you will want to go with a fresh OEM rolling torque value.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  3. #3
    Thank you for the quick reply! You are right, as always, the boat is powered by a V-8 (5.7L). The drive has about 1300 hrs. on it and I'm pretty sure that nothing outside of regular maintenance plus the items listed above has been done to it. It had 900 hrs. on it when I replaced the PDS, bearing crosses etc. This speaks well of Volvo quality. To check the 30207 and 31307 bearings (I'm assuming these are the ones in the bearing box that hold the u-joint shaft) is it necessary to take the BB completely apart or can they be checked by feel, looseness, end play etc. ? Also is there anything else you would suggest I check while it is apart? Thanks
Similar Threads
  1. Out drive question
    By Bret Smith in forum Mercruiser Sterndrive Archive
    Last Post: 09-05-2008, 10:05 AM
  2. Jet Drive Question
    By kimnlj2 in forum Miscellaneous marine engine topics
    Last Post: 06-17-2008, 12:21 PM
  3. 1987 Dixie 299 351 velvet drive drive line question
    By romans116 in forum Pleasurecraft Marine PCM Forum
    Last Post: 03-22-2008, 09:44 PM
  4. 290 Out Drive Question
    By tjwc1 in forum Volvo Penta Gas Archive
    Last Post: 02-20-2008, 12:25 PM
  5. OMC Sea Drive question
    By gus in forum Outboard motors archive 2000-2004
    Last Post: 11-16-2002, 09:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
