Is there a grerase fitting on my gimbal bearing?
[h=2]Is there a grease fitting on my gimbal bearing?[/h]NO...... the gimbal bearing itself will not have a grease fitting on it. :p ;)
However, the Gimbal Housing (aka transom unit) will have the grease fitting that will direct grease to the bearing.
When you add grease, make sure that the engine is running at idle so that the bearing is rotating ( Dynamic -vs- Static! )
