Click for Volvo Penta parts and manuals!
Results 1 to 17 of 17
  1. #1
    Default Volvo dp d1 seals
    I'm replacing the outer shaft seals in my dp d1, they were so bad that they came out in pieces and now I'm not sure how to put the new ones back in there. I'm trying to attach a picture of the way I believe it's supposed to go but for some reason I can't get it to work.
    Any ideas, any help would be great.
    Default Re: Volvo dp d1 seals
    Haven't been able to do it yet as I don't know which way they go, thanks in advance.
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,743
    All dual seals go back to back the inner seal the spring faces the gears and the outer seal the spring faces the prop.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  4. #4
    Quote Originally Posted by kimcrwbr1 View Post
    Awesome, thank you. Now I can take care of this tomorrow.
  5. #5
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,814
    Yes.... the two FWD prop shaft seals (the large seals) are the same, and they install with the lip and tension spring aiming opposite from one another.
    On the oil side..... the lip and tension spring faces FWD towards the gear oil.
    On the water side...... the lip and tension spring face AFT.
    The AFT propeller shaft seals (the smaller seals) are different!
    Use caution here..... and make sure to install them correctly!
    Make dang sure that you re-install the FWD and AFT propeller spacers/washers. Severe damage will occur if you do not!
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  6. #6
    Quote Originally Posted by RicardoMarine View Post
    OK, i did the 2 smaller seal with success as I have the special tool, with the bigger ones I installed the inner one all the way in and the outer one is flush with the lip of the housing, should I push it in a bit more, is it OK if is flush with the lip of the housing or all the way in until it make contact with the inner one.
    Not sure if there should be space between the 2.
    Thank for the help.
  7. #7
    Let me clarify, I have the special tool for the smaller seals, not for the bigger ones, for those I used a big socket and pressed on the inner seal until it made contact with the bearings, the outer seal is flush with the lip of the housing. Does this sound right?
    When you referred to the spacer/washer, do u mean the thick one?
  8. #8
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,814
    Quote Originally Posted by wellcraft26 View Post
    There is a spacer type washer that will be installed in front of (towards the bow) of each propeller.
    The FWD prop spacer is internally splined so that it will pass over the splinned portion of the FWD prop shaft. This spacer stops against a shoulder.
    The FWD prop's thrust is placed against this spacer.
    The AFT prop spacer is not splined. It too will be stopped by a shoulder.
    The AFT prop's thrust is placed against this spacer.
    Both must be installed, or you will cause damage.
    Portland, Oregon
  9. #9
    OK, I just went to check as I remember 1 thick washer but nothing else. I remember removing the cone, then the prop then the rear prop and last the thick washer and that is what I actually have there, I need to order some parts, should I just go ahead and order that other spacer?
  10. #10
    I just watched several videos and they don't even have the washer, they do have 2 covers behind each prop, mine didn't even have that. Wonder if that all depends which model is it. Mine is what I believe a 2003 dp d1, not sure if that makes any difference.
  11. #11
    Btw, in the ID tag it shows as a 1.78 but it has 1.68 gears instead, at least that's what the part number shows from the engraved number in the outer shaft.looking at the exploded view from the UK site and I see the spacers and covers but mine didn't have any of that when I removed both props.
  12. #12
    Hey Ricardo, sorry for all the questions but now I'm confuse and concern about what you said as mine don't have some of the parts and Also, by looking at the exploded view, I see a shim or shims in front of the bearing from the outer shaft, mine didn't have them either. It looks like I'm missing parts from the exploded view, they are #26, #40, #46 and #45, here is the link https://www.marinepartseurope.com/en...-44-10821.aspx
    Thanks again for the help, really appreciate it as I was going to order some parts and I want to add whatever is need it in there.
  13. #13
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,743
    You must mean 36 not 26 is the shims behind the front bearing.
  14. #14
    So the shim #26 goes behind the bearing? If that is the case that explains why I didn't see any shim. I've been looking for the front spacer and can find it, but I don't recall seen it either. Would it be possible that it got stuck in the front propeller?
    I had them in my car for a few days and then took it to a shop to get them fix, wonder it they could have it if it was stuck in the prop. I don't really recall seen that spacer.
    If not, I'm going to have to suck it up and pay the $50 for a stupid washer.
  15. #15
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,743
    #3858457 front prop thrust washer
    #3858458 rear prop thrust washer
  16. #16
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,814
    Let's make sure that we're talking FORE and AFT when discussing this.
    The shims (SEQ# 26) are AFT of the 184765 prop shaft bearing..... not in Front of the bearing!
    These shims control the rolling torque or preload value.
    You will not see these shims unless you have the Hypoid Gear work experience and/or were to disassemble this area!
    Question.... why are you into this area?
    Without these parts, the propeller cannot be mounted.
    Yes!
    These are expens$ve $pacer$...... I would re-trace my steps and ask the shop!
    I don't really recall seeing that spacer.
    Like I alluded to earlier.......... if the FWD prop spacer had been omitted, your prop shaft bearing carrier would have been damaged.
    There are two (2) of these.
    One for the FWD prop and one for the AFT prop..... each is very different from the other!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Duo Prop spacers  line cutters 2 .jpg
    Portland, Oregon
  17. #17
    Thanks ricardo, I do have thexperience bigger one, I'm missing the smaller spacer. I checked in y suv and couldn't find it. I'm going to the house were I removed the props to see if it's there if not I'm going to the prop shop tomorrow and try there. If not, I'll hAve to order that sucker unfortunately. At this point I'm sure that spacer most be stocked in the prop and lost it somewhere.
Similar Threads
  1. Water seals
    By papadog in forum Honda Outboard Forum
    Last Post: 08-17-2017, 06:26 AM
  2. Changing bearings and seals on Volvo penta Bell housing 873183
    By Miclager in forum Volvo Penta Gas Engine Forum
    Last Post: 09-10-2012, 09:40 AM
  3. 15 hp seals
    By edrun in forum Mercury Mariner Outboard Archive
    Last Post: 05-16-2009, 10:56 PM
  4. Water Seals for b93 150 XRI
    By roger_f in forum Mercury Mariner Outboard Archive
    Last Post: 12-02-2007, 11:32 AM
  5. Volvo 270 leg water tube seals oring replacement
    By schredder in forum Volvo Penta Gas Archive
    Last Post: 07-14-2006, 11:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
