Results 1 to 6 of 6
    Default What Gray Marine Engine do I. Have?
    Hello everyone,
    I've just aquired a Gray Marine Engine Model 115 / Eng#G7380 w/Venith Carb tag#10870 Do I need any other information to determine displacement, hp, approximate age, etc? I have photos if needed. Thank you!
    Sep 2008
    Maryland - USA
    6,882
    Default Re: What Gray Marine Engine do I. Have?
    may want to post at the sister site: www.oldmarineengine.com....they have active membership on their gray marine page.
    this may be of use as well:
    http://www.finewoodboats.com/Gray.htm
    Thank you very much "makomark" for the information! I will check out that group.
    Sep 2008
    Maryland - USA
    6,882
    you're welcome....hope it helps!!
    I'm guessing that is a flat head six that is probably based on the 226 CID Continental industrial engine. you should be able to find "226" cast into the block near the oil pan flange, probably under about where the oil pump is.
    At least this is the case with the Gray 109. I suspect the 115 is about the same engine with maybe a bigger carburetor.
  6. #6
    Hi,
    You have a 1950's 224 cu.in engine with zenith 63m2e12 spec10870 carb also used on lugger exp6-226 &luggerexp6-224.
    Charlie W
  1. Gray marine 327 engine indentification
    By tim72 in forum Gray Marine Gas Engine Forum
    Last Post: 09-17-2011, 01:13 AM
  2. gray marine engine
    By [email protected] in forum Gray Marine Gas Engine Forum
    Last Post: 07-07-2010, 03:56 PM
  3. Gray marine engine Identificatiom
    By Lance Nesta in forum Gray Marine Gas Engine Forum
    Last Post: 07-20-2008, 12:42 PM
  4. Looking for a 1962 Gray Marine 225 HP 327 CI Engine
    By John Price in forum Archive 2002-2006
    Last Post: 12-29-2001, 11:43 PM
  5. Gray Marine 225 Hp gas engine need parts
    By Ron Conway in forum Archive 2002-2006
    Last Post: 03-12-2001, 11:02 PM
