Results 1 to 2 of 2
  1. #1
    Default 1977 35hp and 25hp same year are gear box interchangeable??
    Hi all i have a 1977 Johnson 35hp 2 stroke with gear box that wont go into reverse dog clutch is worn iv found a cheap complete leg from a 25hp just need to know if they are interchangeable thanks john
  2. #2
    Default Re: 1977 35hp and 25hp same year are gear box interchangeable??
    Only the 1985 and later 25 hp gearbox will fit your motor. The 1977 35 hp uses through hub exhaust and the 25 hp did not get that until 1985.
Similar Threads
  1. Coils on 1977 35hp
    By Havinfun in forum Johnson Evinrude Outboard Forum
    Last Post: 09-05-2015, 03:42 PM
  2. 1977 Evinrude 35hp Carb
    By richiniowa in forum Johnson Evinrude Outboard Forum
    Last Post: 07-09-2011, 03:35 PM
  3. 35HP evenrude 1977.
    By hawaiian547 in forum Johnson Evinrude Outboard Forum
    Last Post: 03-19-2011, 09:00 PM
  4. overheat 1977 35hp
    By jim fogle in forum Johnson Evinrude Outboard Forum
    Last Post: 10-24-2010, 11:38 PM
  5. 1977 35hp johnson
    By plonthedl in forum Johnson Evinrude Outboard Archive
    Last Post: 05-15-2009, 10:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
