Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 4 of 4
  1. #1
    Default 1987 85 hp force - rough idle and only 2500 rpm at WOT
    All,
    I have 1987 85 hp force that has always run perfectly. The other day (the first time I ran it this year) I was on the river and cruising at 35 mph at 5000rpm. I ran into some wakes and got bounced around a little and throttled down. When I went to pick back up the motor would max out at 2500 rpm and about 8mph. After limping back to the dock the motor also idled rough...it will rev up and then clunk...repeatedly. It still starts immediately and idles smooth for the first 30 seconds and then gets rough. It still will not exceed 8 mph at WOT. Since then I have checked the compression which was 120 ish on all three cylinders and all three cylinders are getting spark. I took off the carb cover and sprayed gas into each cylinder while it was running to check for any change. When I sprayed continuously into the middle carb it seemed to smooth out. Since then I have taken the carb off and given it a thorough cleaning but when I put it back on there was no change in performance. I am perplexed since it was running so well right up to this point. If anyone has any additional ideas I would greatly appreciate it. I currently have the fuel pump off and found no tears in the diaphragm but I will change it anyway. Thank you in advance!!
    Scott
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,517
    Default Re: 1987 85 hp force - rough idle and only 2500 rpm at WOT
    Spark check?
    Check all the cable and wire connections.
    Trigger wires are thin and break easily.
    outboardignitiondotcom has test procedures.
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
  3. #3
    UPDATE: Well...it was the bottom carb. It had fuel pouring out of the side of the bowl (should have noticed that...) the gasket had crumbled and was all through the bowl and in the jets. I replaced the carb and it took off!! Thank you!!
  4. #4
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,517
    YEA!!
Similar Threads
  1. 1993 Johnson 521cc rough start, rough idle, keeps coughing
    By samppa in forum Johnson Evinrude Outboard Forum
    Last Post: 05-09-2014, 05:13 AM
  2. 1987 won't go past 2500 rpm
    By dish_moose in forum Mercruiser Sterndrive Forum
    Last Post: 07-01-2012, 04:40 PM
  3. Rough Idle Rough on slow take off
    By catfish1969 in forum Johnson Evinrude Outboard Archive
    Last Post: 09-16-2009, 03:57 AM
  4. 1987 200225 rough idle
    By grrrrpower in forum Johnson Evinrude Outboard Archive
    Last Post: 04-14-2007, 03:36 PM
  5. 1974 evinrude 25hp hard start rough idle dies at low idle
    By mike gray in forum Johnson Evinrude Outboard Archive
    Last Post: 05-16-2006, 03:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
