Have a 03 502 330 hp crate motor in a 18 ft jet come in for a no start. Found bad fuel pump and starter, replaced with marine parts, started up no problem but has terrible valve noise. Pulled valve covers and found non adjustable rockers. I have no history on engine, has 60 lbs oil psi and 180 compression. My question is this a common problem with this generation engine? If so is the fix lifter replacement or converting to adjustable rockers? Also has electric fuel pump with oil shut down, can I use the by pass connection on starter to turn on fuel pump when cranking? Seems strange not to have pump on when cranking and have to wait for oil psi. Any ideas on what oil viscosity to run since I want to change oil due to owner not knowing. Yes I know this isn't a Mercruiser question but Mercruiser runs this gen engine in some applications. Thanks for any help,Guppy
