Click for Volvo Penta parts and manuals!
Results 1 to 3 of 3
  1. #1
    Exclamation AQ125A won't stay idling
    I've got an 84 bayliner Capri with the 4 cylinder AQ125A engine and a solex 44PAI downdraft carb, I have replaced the spark plugs, plug wires, cleaned distributor cap and points and regapped the points to 20,000 not sure if that is the correct amount or not? Also I have rebuilt the carburetor but I cannot seem to keep it idling in neutral, it will idle at roughly between 1000-800 rpm momunterally and then slowly looses power and stalls out on me, I have tried adjusting the idle and mixture screws the best I can but does not seem to be helping..... any suggestions?
  2. #2
    Join Date
    Dec 2016
    Location
    Cave Creek, AZ
    Posts
    61
    Default Re: AQ125A won't stay idling
    I fought this type of issue with my 92 230B and a solex. The solution, which would have saved me a ton of headache if I knew it sooner, was to spend the $100 on a pertronix ignition module. It replaces the points. And that is ultimately where my issue was (after weeks of troubleshooting spark strength). If you haven't done a pertronix, I highly recommend it.
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,730
    Get a cheap dwell/tach and set the points at 62 degrees dwell mine is just above .016". After you get the dwell at 62 degrees then set the base timing at 6 degrees BTDC. There are two types of the 44PAI if the idle air needle has the wide head for larger screwdriver preset at 2 turns out from lightly seated if it has the small head pointed straight at the head turn it out 9 1/2 turns from lightly seated. Every time you adjust point gap you must adjust the base timing.
    I had performance issues with the pertronix ignition and went back to the points when I found the coil was getting hot. I put a ballast resistor to coil pos and she purrs like a kitten.. Put your hand on the coil after running for a bit if it gets hot to the touch just put a ballst on it it should help alot and keep from cooking the points.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
Similar Threads
  1. BF 40 Idling
    By JPasadena in forum Honda Outboard Forum
    Last Post: 09-02-2015, 08:13 PM
  2. 1988 suzuki DT115 won't stay idling
    By edinct in forum Suzuki Outboard Forum
    Last Post: 08-02-2011, 02:57 PM
  3. Aq125a
    By ryno1981 in forum Volvo Penta Gas Archive
    Last Post: 09-04-2008, 01:55 AM
  4. Need much help on AQ125A
    By music_is_my_life in forum Volvo Penta Gas Archive
    Last Post: 02-15-2008, 04:15 PM
  5. Volvo penta AQ125a wont stay idling
    By diam88 in forum Volvo Penta Gas Archive
    Last Post: 08-20-2007, 04:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
