Click for Crusader parts and manuals!
Results 1 to 6 of 6
  1. #1
    Default Riser Pass Thru Plate
    Hello,
    I have twin 8.1's with fresh water heated risers. There are 2 metal plates on each riser, a pass thru and a blocking plate. I understand the need for the blocking plate but not the pass thru plate. Is the pass thru plate necessary and can just a gasket be placed there instead ?
    Thank You
    Smbdck
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,884
    Default Re: Riser Pass Thru Plate
    the 8.1 uses what they call "wing plates" and they come in the blocking and pass thru configurations. I suspect it is due to the 'wing' around the exhaust passage. My understanding is that it is there to "catch" any water (which shouldn't be in that area of the passage).
    on the 'heated riser' configuration the block off version goes between a pair of gaskets and that assembly goes between the riser and the elbow. (Same assembly would go between elbow and manifold in a no-riser setup.) the riser-manifold uses the pass thru plate between a pair of gaskets. I don't see the need for the lower wing plate if the upper one is installed. as a general rule, unless they are damaged, either plate can be reused with new gaskets....
  3. #3
    Quote Originally Posted by makomark View Post
    Thanks for your response. I agree, there really is no need for the lower pass thru wing plate. I guess there is no way to contact Crusader anymore and ask them.
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,884
    There Tech support dept still answers the phone - but, to be honest, I haven't called in a couple months. That said, I wouldn't expect any answer provided to deviate from the original (production) configuration.....
  5. #5
    Join Date
    Dec 2008
    Location
    Bourne, MA, USA
    Posts
    310
    I believe the wing plates are designed to catch and boil off any water/moisture that may run down the inside of the riser or elbow to keep it out of the engine.
  6. #6
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,646
    In the MERCRUISER world, they are called "turbulators" and catch condensation that forms on the inside of the elbows when engine first starts under most weather conditions.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
Similar Threads
  1. Leak at riser stud after installation of new riser and elbows.
    By Ngeogh in forum Crusader Marine Engine Forum
    Last Post: 07-12-2011, 12:42 AM
  2. PCM 5.8 HO wont pass 2500 RPM's
    By Jeff19 in forum Pleasurecraft Marine PCM Forum
    Last Post: 06-03-2011, 12:09 AM
  3. Can't pass 2000 rpm
    By seungjoonyi in forum Mercruiser Sterndrive Forum
    Last Post: 08-09-2010, 07:58 PM
  4. TAMD40 not getting pass 2250 RPM
    By foxy in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 05-02-2008, 08:34 PM
  5. Manifolds Riser Spacers Riser Elbows
    By schachtvestcorcom in forum Crusader Marine Archive
    Last Post: 09-19-2007, 05:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
