Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 4 of 4
  1. #1
    Default How to get gear off of tiller rod?
    I bought a plastic bearing because the one on the tiller broke, which disabled the acceleration. However, there is a little gear I need to remove from the rod so I can slip on the plastic piece. Any ideas how to get the gear off and back on safely?
    Eric
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	16324   Click image for larger version.
ID:	16325   Click image for larger version.
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,417
    Default Re: How to get gear off of tiller rod?
    Top pic shows a tiny hole.
    In that hole i a spring pin/ roll pin.
    It needs to be driven through.
    They sell spring pin driver sets.
    The set come with 5-6 drivers all made to fit the different size pins.
    https://www.googleadservices.com/pag...QvhcIUA&adurl=
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
  3. #3
    Thanks! I'm about as mechanical as a squirrel. I'll get a spring pin driver set.
  4. #4
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,417
    Fill out the profile add a signature.
    That way we can see where your from.
    'You might be close to someone who can help??
Similar Threads
  1. 2002 40 4 stroke tiller- noise in gear.
    By Brandon McGaw in forum Yamaha Outboard Forum
    Last Post: 05-20-2015, 05:50 PM
  2. Replies: 22
    Last Post: 03-26-2014, 05:55 PM
  3. why can't i go to gear in tiller
    By Sierra015 in forum Mercury Mariner Outboard Forum
    Last Post: 08-07-2012, 07:59 PM
  4. Replies: 1
    Last Post: 07-20-2011, 05:30 AM
  5. Replies: 3
    Last Post: 08-07-2006, 11:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
