Results 1 to 7 of 7
  1. #1
    Default 225 tilt trim plug?
    I need the female plug that goes on the wiring harness for the tilt trim switch inside the motor cowling. The switch stuck and the motor came down and continued running and overheated the plug and burn one of the female pins inside the plug. I need the female plug so I can splice the plug back in and get the tilt trim working again. Any help is appreciated, thanks.
  2. #2
    Default Re: 225 tilt trim plug?
    Can you imagine how many 225hp engines Yamaha has produced in its 30+ years of producing outboards, including different models for each year?? I can. A lot, that's how many. So let's start over. What's the year and model number of your engine.
  3. #3
    2002 Yamaha 225 four stroke. I'll have get the model #. Thanks.
  4. #4
    F225txra is the model.
  5. #5
    To my knowledge the plastic harness is not a replaceable part. You'd have to replace the entire T/T switch assembly. Part # 69J-82563-01-00, which will cost around $45-$50. Another option if available in your area, is find a marine surplus store that has broke down engines. Take the old harness with you to compare, find a yamaha V6 engine, and either cut off the harness or take out the entire switch assembly.
  6. #6
    I have already replaced the switch. I need the female side that goes on to the wiring harness. Thanks.
  7. #7
    Quote Originally Posted by trx125 View Post
    I believe you're referring to the engine side PT/T harness. And again, I don't believe the 4-pin harness itself is sold separate from the main wire harness.
Similar Threads
  1. trim tilt doesnt trim tilt on my 1987 70 hp johnson outboard
    By OBG in forum Johnson Evinrude Outboard Forum
    Last Post: 10-15-2016, 02:05 AM
  2. Replies: 1
    Last Post: 05-25-2016, 02:57 PM
  3. Mariner tilt and trim filler plug
    By billnorfolk in forum Mercury Mariner Outboard Forum
    Last Post: 06-10-2015, 05:29 AM
  4. 1993 Johnson 48 spl tilt and trim retainer plug removal.
    By rivins in forum Johnson Evinrude Outboard Forum
    Last Post: 08-04-2012, 02:14 AM
  5. 48 hp johnson trim and tilt plug
    Last Post: 08-03-2012, 09:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
