Battery connection for MFS 25
Chick Ludwig
What terminals are the battery cables attached to? A diagram or photo would be great.
The ground is attached in the picture, but I don't think it is in the right place.
STOP.
The positive goes to the starter relay. Ground to any good ground; I believe there's a ground terminal on the starter frame on your model.
Apparently this project exceeds your current skills. You should seek the aid of a local automotive or marine mechanic. However:
Find the starter. Trace the big wire to the starter relay. The + battery cable goes to the other lug on that relay.
Any block ground is OK. There is a ground lug near the top of the starter frame.002-21050-8_FIG09.jpg
Thanks Paul, the illustration helped. Everything works as it should now. I didn't realize that the terminal next to the one the heavy wire to the starter was the one I wanted. I'm not very familiar with this kind of wiring, but I knew that one of you guys could help.
