Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 5 of 5
  1. #1
    Default Battery connection for MFS 25
    What terminals are the battery cables attached to? A diagram or photo would be great.
    The ground is attached in the picture, but I don't think it is in the right place.
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,254
    Default Re: Battery connection for MFS 25
    STOP.
    The positive goes to the starter relay. Ground to any good ground; I believe there's a ground terminal on the starter frame on your model.
    Paul
    Buffalo NY USA
  3. #3
    Which terminal is the starter relay? There is no ground terminal on he starter frame that I can find.
  4. #4
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,254
    Apparently this project exceeds your current skills. You should seek the aid of a local automotive or marine mechanic. However:
    Find the starter. Trace the big wire to the starter relay. The + battery cable goes to the other lug on that relay.
    Any block ground is OK. There is a ground lug near the top of the starter frame.Click image for larger version.
    Paul
    Buffalo NY USA
  5. #5
    Thanks Paul, the illustration helped. Everything works as it should now. I didn't realize that the terminal next to the one the heavy wire to the starter was the one I wanted. I'm not very familiar with this kind of wiring, but I knew that one of you guys could help.
Similar Threads
  1. NO Fuel NO Spark after reverse battery connection:(((
    By gs963 in forum Suzuki Outboard Forum
    Last Post: 08-10-2017, 10:00 AM
  2. battery connection 1977 175hp
    By scanner in forum Johnson Evinrude Outboard Forum
    Last Post: 04-05-2012, 08:09 AM
  3. Connection points for battery cables on Optis
    By Captain Swag in forum Mercury Mariner Outboard Forum
    Last Post: 12-12-2011, 08:25 AM
  4. Battery connection help
    By jeff6898 in forum Johnson Evinrude Outboard Archive
    Last Post: 09-20-2008, 12:16 PM
  5. 1986 150 HP Battery connection
    By rsh19904 in forum Yamaha Outboard Archive
    Last Post: 07-19-2006, 11:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
