Click for Honda Manuals, Parts and Model Guides!
Results 1 to 8 of 8
  1. #1
    Join Date
    Mar 2009
    Location
    Cincinnati, OH USA
    Posts
    4,389
    Default Need recommendation for anti-corrosive spray for a 90 Honda going to be in salt water for 3 months
    As the title says...
    I have a customer who is taking a fairly new Honda 90 on a workboat to saltwater for a job for three months.
    Being in a fresh water area, we only use light weight stuff.
    I would like to spray something on the motor before he picks it up.
    I know I will get many different replies....but bring them on.
    Most of you have more experience with the ocean and her fury than I.
    Thanks.
    Mike
  2. #2
    Join Date
    Mar 2013
    Location
    Merritt Island FL
    Posts
    49
    Default Re: Need recommendation for anti-corrosive spray for a 90 Honda going to be in salt water for 3 mont
    I use corrosion X - they make several different types - it works great on the engine, trailers, axles etc. aerosol seems to coat things better
    http://www.corrosionx.com/
  3. #3
    Boeshield under the cowling.
  4. #4
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,211
    I think Corrosion X and Boeshield T-9 are very similar products. I've never used the Beoshield. I can attest to the effectiveness of Corrosion X on preventing rust and corrosion. I just wish I had known about it when I first got my engine.
    CHawk 25 DLX
  5. #5
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,891
    Mercury/Quicksilver Parts * Corrosion Guard - 11 OZ 92-802878Q55
    A rust inhibitor that forms a water-resistant barrier on non-painted and painted surfaces. Use to prevent rust from forming on out drives, lower units and power trim motors and components or other metal surfaces. Can also be used to prevent further paint damage in areas where undercutting and blistering have occurred. Do not spray on surfaces coated with antifouling or biocide paint. Do not spray on drive belts.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  6. #6
    Join Date
    May 2016
    Location
    Melbourne FL
    Posts
    15
    Crc heavy duty crossion inhibitor also lays down a film.
    Between crc, starbrite and 303 ive found most of what i need to maintain my boat
    Tigerfish
    Melbourne FL
  7. #7
    Join Date
    Mar 2009
    Location
    Cincinnati, OH USA
    Posts
    4,389
    Thanks for all the replies. Just have to check which one/s our distributers carry.
    Mike
  8. #8
    No anti corrosion spray is needed. If you must, uses CRC marine heavy duty corrosion inhibitor. Apply to the steer bracket and very lightly to some of the under cowling area.
Similar Threads
  1. 1977 evinrude 70hp no water spray at all.
    By Christopher Chidester in forum Johnson Evinrude Outboard Forum
    Last Post: 04-09-2016, 01:36 PM
  2. How to COMPLETLEY drain AQ120B raw water pump during freezing months
    By DKaiser in forum Volvo Penta Gas Engine Forum
    Last Post: 03-06-2016, 01:19 AM
  3. Should Water pour out or spray out of your exuast?
    By Jfreeman1412 in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 06-25-2012, 06:49 AM
  4. water spray not stream from pee hole
    By wassajet in forum Johnson Evinrude Outboard Forum
    Last Post: 06-17-2010, 02:00 AM
  5. Dirty water spray in engine compartment
    By cbell2112 in forum Volvo Penta Gas Archive
    Last Post: 09-04-2007, 12:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
