Results 1 to 6 of 6
  1. #1
    Default Yamaha 115 shifts fine out of water but hard to shift into neutral in water
    I just test dipped my motor today on my project boat. On the hose you can shift into forward to neutral to reverse and vice versa. In the water today It was stiff shifting back to neutral from forward and as well as from reverse. A couple of times it passed straight through neutral to reverse. Any help would be appreciated!
  2. #2
    Default Re: Yamaha 115 shifts fine out of water but hard to shift into neutral in water
    Year and model?
  3. #3
    Sorry I thought I included that. It's a 2000 Yamaha 115 xtry.
  4. #4
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,826
    First, Look right above the lower unit at the shift rod. I know Yamaha improved the rod for rot, But I always check it. If it looks like two pencil points touching, there is your problem.
    Second, if the shift rod looks fine, Look under the intake of the power head and make sure the shift rod pivot is not broken.
    Third, disconnect the cable at the engine and see if the shift slide moves freely.
    Fourth, If everything above is good, pull the lower unit off and make sure the splined coupler that is welded to the shift shaft has not broken loose.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  5. #5
    Great thanks for the info. When I get home and check it out I'll let you know! Hopefully it will be an easy fix!
  6. #6
    Check your idle speed If its set too high it will be hard to get out of gear and into neutral.
Similar Threads
  1. hard to shift in neutral when in water
    By deckboat in forum Yamaha Outboard Forum
    Last Post: 10-03-2017, 12:52 PM
  2. Replies: 1
    Last Post: 06-06-2017, 12:26 AM
  3. Merc 90 Reverse Fine, Neautral Fine, Forward fine until a load then switches to neutral
    By Chucktowndcroz in forum Mercury Mariner Outboard Forum
    Last Post: 04-29-2016, 04:11 PM
  4. Replies: 17
    Last Post: 09-19-2011, 11:12 PM
  5. 5 HP Yamaha shifts hard
    By Roger Breunig in forum Yamaha Outboard Archive
    Last Post: 10-29-2007, 12:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
